8550 hydraulic noise/vibration
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: 8550 hydraulic noise/vibration
    Posted: 10 Oct 2017 at 8:47pm
The pump on the rear end has made a load whine/groan noise as long as I've owned it (10 years),sounds like its running out of oil. Its not constant,it comes and goes all on its own. When it does this the big line that goes to the spool valves and PTO valve will vibrate rapidly. It has no effect on hydraulic functions. Any ideas?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 8:56pm
Most likely a hydraulic line touching metal somewhere.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 10:27pm
No this is something internal and loud. All the lines are isolated. When a remote lever is pulled it makes a similar sound just not as loud. But like I said it's spuratic whether tractor is just sitting idling or out working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 10:00am
Bump
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 8:41pm
have you ever checked stand by pressure? Darrel
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 10:07pm
Like Darrel said, check standby pressure, to make sure its not running in high pressure mode all the time, does it have 3 point? feedback linkage could be out of adjustment causing it to run in high pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 10:18pm
No I haven't checked pressure. Doesn't have a 3 point. If the pressure is high what needs to be done?
rustydollar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustydollar Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 10:42pm
The reason your hydraulics work fine is because the first pump in your hydro unit is the charge pump.
Charge pump has implement ports that supply hydraulic oil for the tractors accessories.
I would suggest changing the filter, if it's obstructed in any way the charge pump will be short of a continuous oil supply.
When I change a filter I always cut it open to examine the paper cartridge for foreign material. No metallic particles is always good news.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 7:14am
Connect a 3000 psi gauge to the JIC tee with the cap on it on the side of the PTO valve. Remove the cap and connect the gauge. Pressure with engine running should be a steady 350 to 600 psi with hydraulics at rest. Pressure should be a steady 2500 psi when you activate and hold any remote lever. What do you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 12:34pm
I'll check pressure this weekend.
