AC serial number location
Smiling John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smiling John Quote  Post ReplyReply Direct Link To This Post Topic: AC serial number location
    Posted: 14 Sep 2017 at 9:07am
Is there a listing of the location of the serial numbers on AC tractors?  Thanks.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 2:50pm
Not that I recall at the moment.
B, C, CA, is at the base of the gearshift lever.
WD/WD45 is above the left rear brake spring hole
"D" Series up to D17 is on the rear left side of the engine on the bell housing
D19 is on the back center edge behind the seat mount. It might be covered up with oil & dirt or a hydraulic line, or both.
Hope this helps you for starters.
How blessed we are by HIS GRACE!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 2:55pm
The Allis Chalmers Story by C H Wendel has that information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smiling John Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 1:33am
Thank you both very much.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 5:01am
Here is a link to Bryan Smiths Webpage.
Lots of technical info. for Allis Chalmers.
For a list of Serial No. Locations, find it in the R/H column.
Gary
http://wsmth.people.clemson.edu/index.htm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 4:40pm
The Steiner catalog has locations as well as serial number breakdowns.  This page also has year charts under the home page - serial numbers.
AaronSEIA
