190XT?
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Topic: 190XT?
    Posted: 05 Sep 2017 at 5:26pm
On the right hand side of the engine there are two hoses about 2in. long . Are they something special or just radiator hose? Thanks.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2017 at 8:15pm
Nothing special.Most automotive stores will have that size in bulk and just cut off what you need. They really should have that thin heat shield put back to protect the hose from the exhaust heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2017 at 8:20pm
Those hoses are for the oil cooler.  AGCO carries them.  Also go and get STAINLESS STEEL gear clamps to secure them.  Ordinary gear clamps are not strong enough to keep them from leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2017 at 9:23pm
Automotive stores locally didn't have that size hose when i replaced mine. Don't remember the dimension, but checked 4 stores and no one had it. Luckily my brother had some left over. Book recommends some silicone rubbed inside the hose lip to help seal from leaks. It works, no leaks in probably 30 hours of run time.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2017 at 9:32pm
Clamp the hoses then put heat shield over hose and clamps. Then put one hose clamp over middle of heat shield.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 2:16pm
Ok thanks mine don't have any heat shield on them.
