175 engine swap
BV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BV Quote  Post ReplyReply Direct Link To This Post Topic: 175 engine swap
    Posted: 20 Jul 2017 at 10:16pm
Has anybody put a 200 ci turbo engine in a 175, how hard and any pics please?
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 10:35pm
I've been dreaming of doing it for years. To properly do it, you'd need to swap a d17 series 4 DIESEL input shaft. Then just use a 180-200 adapter plate flywheel and clutch. I would think it would go right together. If it had a front mount pump, I'd just somehow make it work off the regular pump mount like on the 6000 series or 100 series. But if torque tube mount, have the clutch builder put the splined piece from The 170-175 pressure plate on the 180-200 plate. Think this would make a excellent fuel efficient little 70-80 up tractor. Put a set of 16.9r34 or 18.4r34's on and you'd be cookin!
Edited by peterson - 20 Jul 2017 at 10:37pm
Chad S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad S Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 7:39am
36 WC,41 WC,53 WD45,57 D14,65 D21,68 XT,72 XT,81 7045
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 8:08am
I would just use a new -rebuilt Perkins 4T-236 with turbo! https://www.perkinsqm.ca/en/4-236-series/t4-236-engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 9:47pm
There are tons of 248 Perkins engines out there which will drop right in.  Lots of Massey tractors used them.  You can also rebuild the the Perkins that you already have.
This page was generated in 0.110 seconds.
