7040 PD troubles |
Lynn TN
Joined: 29 Nov 2009 Location: Maryville, TN Points: 130 |
Topic: 7040 PD troublesPosted: 12 Jul 2017 at 7:49am |
Been bushhogging with our 7040 when you load the tractor either by being in thick weeds or going up hill the PTO will slow way down then the ground speed will nearly stop as well. When you stop and let it clean out it will go again fine. Filters are good as well as both sections full of oil. Didn't know if it's a pump problem or what. Tractor has 7000 hours but hate to junk it still looks and runs good.
Posted: 12 Jul 2017 at 7:57am |
Sounds like torque limiter on the flywheel.
Lynn TN
Posted: 12 Jul 2017 at 8:16am |
Meant to also say transmission pressure above 1800 light stays on till pretty much wide open as well and back on when it slips.
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 12 Jul 2017 at 8:58am |
No need to junk it, if it is the Torque limiter, you just need to split the tractor and replace it, just like the dry engine clutch of old. You will likely need to take a hard look at your flywheel, and the pressure plate, if it has been slipping like that for long, likely it is shot from heat stress.
Still in use:
MACK
Posted: 13 Jul 2017 at 9:52pm |
Have flywheel resurfaced, new disc, and new pressure plate. Never mix old with new parts in a torque limiter. MACK
