Ignition Question |
cnafarms
Joined: 01 Jul 2011 Location: Mt. Airy, MD Points: 140 |
Topic: Ignition QuestionPosted: 11 Jul 2017 at 8:22pm |
I have an electronic ignition on my D17. Have had it on there for almost a year no problems. Has started right up and ran like a top. Used it with the electronic ignition last year for 3rd cutting hay all winter putting hay out as well as 1st cutting hay this year. Went to start the other day have nothing. Pulled plug wire to see if there was spark nothing. Got a test light and have juice going into the distrubotor but nothing coming back out to coil. So has the electronic ignition gone bad or is it something else. The coil is one of the flame thrower coils.
DougS
Posted: 11 Jul 2017 at 8:30pm |
It could be the coil. Put an ohmmeter across the two coil terminals and see if it reads around 3 ohms. The odds are greater that it's the electronic ignition.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6554 |
Posted: 11 Jul 2017 at 8:55pm |
Had basically the same problem with my D15, ran great for about a year and a half, then only intermittent spark about two months ago. Went back to points and condenser and it runs great.
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 12 Jul 2017 at 7:59am |
Try pull starting your D17 before starting to chase down the cause. Recently fixed the neighbors D14 W/ Petronix and Flamethrower (I installed it and sold him the tractor several years ago). It has started and ran great all these years for him. Then all of a sudden, and with no prior symptoms, would not start with the starter; started right up and runs great with a short pull. Did a voltage test to the coil; 12.5V w/o starter. 8V with starter. Re-installed the points/condenser and now starts and runs great. I told him the starter was dragging too much and lowering the voltage to the ignition. The Petronix ignition is more sensitive to voltage changes than points. Told him that pulling the starter and working on it was in his future, could be as simple as cleaning the groves and/or emorying the commutator and/or replacinf the brushes. Once he cures the starter drag issue, he can reinstall the Petronix ignition.
Others here can provide a real good description of the electrical theory and fixes for significant voltage drops.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54751 |
Posted: 12 Jul 2017 at 6:26pm |
Also check your battery connections, and voltage. Pertronics are voltage sensitive, as noted, above...
