190 XT pulling better this year |
Beirnesy
Orange Level Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
Posted: 08 Jul 2017 at 5:59pm |
put a BW s200 on for this season , seems a lot stronger , 4th low(7th) still wondering if I should cut the fuel back some.
Edited by Beirnesy - 08 Jul 2017 at 7:02pm |
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Allisplumber
Bronze Level Joined: 04 Jan 2016 Location: Wisconsin Points: 76 |
I run a 200 and what helped me was putting a smaller exhaust housing on the turbo and driving the turbo harder so you don't fall under the turbo on the end , I don't know what you are building for boost ? Allischalmers 301 engines don't breathe very well , doesn't look like to much fuel to me , step the exhaust down one step and try that , thinking that will help you a lot , I build around 48 psi of boost and spin out at the end every time .
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7970 |
Good looking tractor,, it definetly fell off at the end , id try Allisplumbers idea, I wouldn't back the fuel down, its a good black, its keeping the flame down , flames out of the stack look cool, but it means stuff under it is HOT !
Beirnesy
Thanks for the advice, it is the .83 A/R turbine housing
Allisplumber
I would step that down 2 sizes , the 301 motor will not over turn that big turbo unless you have some major head work done to it , I'm only running a .58 on mine but my turbo is smaller then the s200 , good luck hopefully that will keep it alive for you
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4793 |
The .83 is pretty small. I think you drowned it with fuel at the end. That pump had enough fuel to feed a 426. It takes heat to drive the turbo.
Beirnesy
should I turn torque screw in a 1/4 inch, or would that cause complications in other sections of that built pump ? Thanks for advice as well ED.
Edited by Beirnesy - 10 Jul 2017 at 12:12pm |
Orange Level Access Joined: 12 Sep 2009 Points: 19645 |
Ice water intercooler.
Beirnesy
Thats what my 18 year old son keeps telling me, and you can never go wrong with a cooler charge of air, but not allowed if I want to pull in OTTPA, although when your AC is 100 C I less than rest the class, maybe they should allow. I should mention it makes 55 lbs boost quite easy .
Edited by Beirnesy - 17 Jun 2018 at 8:56am |
injpumpEd
try running the torque screw in, and a 1/4" would make a difference I'd think, but I haven't seen that pump in so long, that I can't even guess where the screw was set. I would have left it wide open last time I had my hands on it. It will not hurt anything.
KevinON
Orange Level Joined: 07 Dec 2009 Location: Schomberg, ON Points: 786 |
Looking good.
Beirnesy
This weekends hook, having fun
https://www.youtube.com/watch?v=mT1iReGOfmI
Edited by Beirnesy - 21 Jul 2017 at 9:24pm |
DougG
That's the way it's done! Very nice!
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4713 |
Good looking 190. What tires are you running? Is the rear end stock and if so have you had any issues? I pull mine in the stock farm class. Ed has done his magic on the pump, and I put in a 6 puck clutch. I had plenty of power and spun out. Previous owner put tires on from the local coop. Okay for the farm but not for pulling. Would love to have some Firestone radials.
Beirnesy
tires are Good Year dyna torque, they where cheap, not my favorite tire. Has new 3rd and 4 th A&I gears, sliding collar, shift fork.
Beirnesy
2018 UPDATE. New steel flywheel and double disc clutch from ATLAS tractor, (very smooth instalation and works great). Boost pressure runs 52-54 psi and exhaust pressure at 32 psi. BW S200 57 x 61 with .83 exhaust housing. should I go with tighter exhaust housing ?
first hook in 3 high track very tight, second hook in 4 low. Edited by Beirnesy - 17 Jun 2018 at 12:20pm |
injpumpEd
From the catalog I have the .83 is the smallest A/R ration housing offered for the S200. With the exhaust pressure being as low as it is that would probably explain why it dies off so fast when the load hits. Almost think the 52mm S200 would have balanced better. Everyone thinks bigger is better.
dawntreader74
Orange Level Joined: 28 Oct 2013 Location: Manteno Points: 1761 |
shorter tire will sure keep the rpm's up. even if you went up a gear ?
