STARTER FOR 20-35
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: STARTER FOR 20-35
    Posted: 02 Jul 2017 at 9:21pm
I saw a starter put on a 20-35 that used a ford starter which has a long shaft and riged together with v belts down to the pulley. Does anyone have any pictures of this set up or a better idea. I am getting to old to crank this tractor either I am going this route of some type of a starter or I will be forced to sell it. Thanks Dave
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 9:36pm
I can't help you, but speaking of starters on old tractors, Gilbert Vust mounted a ring gear from a John Deere D on his Allis 10-18 (minus a tooth or two) and added a starter that way. Looked professional for sure to me!
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 10:44pm
I have seen a few older F series Farmall tractors that have a truck flex plate mounted up to the pto or belt pulley and have a mount made for a truck starter.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 6:17am
  Dave pending on how much u get it out any more ,Belt it up to another tractor .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 8:57am
Problem is that I take it to a show and the last two times I get it started at the show a lot of times just to show it off. When I get home and try to start it on the trailer then I have a hard time to get it started. That is why I want to put some type of a starter on it. Thanks Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 9:11am
Time for a pony motor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 7:30pm
ANY BOBY HAVE ANY PICTURES OF A SETUP LIKE THIS?
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 10:41am
Only in my dreams.  You don't dream about girls when your married to the best.
Yes I been thinking of rigging a starter for My E for a long time.  Even a jack shaft with belt pulley off the back of my 716 V belted to the bevel box.  But I see your point in starting it on the trailer.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 10:55am
Dave 63 ,why go do all that when u can put a starter set on the  E 25-40
