45 hand clutch
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Topic: 45 hand clutch
    Posted: 20 Jun 2017 at 4:16pm
Need some further help.  Got hand clutch cover off and have a manual, but not sure what is up.  I have taken 2 of the bolts out on the basket and took the 1/8 inch block out of one position.  Thought there were shims, but no.  The manual just points to that and calls it shims.  Looks like I have excess clearance between plates.  Do I replace this block with shims, a narrower block or what?  Wish I was older so I could remember what what my dad did.  Other question is were would I get shims?  Yesterdays tractor does not list them.  Thanks for any and all help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 4:36pm
You may want to look at that "block" closer.  The shim pack is so tight that it may
look like one piece of metal.  If it is one solid block, I do not have an answer to
your question.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Pilot172000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pilot172000 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 4:48pm
Thinking of doing same.  Did you break the tractor in half to pull the hand clutch off?
Behind every great farm is an orange tractor!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 7:33pm
Like said above the shims might be stuck to the spacer blocks, if there's no shims left and you have to much clearance between plates it might be time to over-haul the hand clutch.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 8:20pm
Agree, when I took WD apart the shims were so stuck together you thought it was one piece. Took a knife and started scrapping and found out it was several pieces.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 8:55pm
when you go to repairing the hand clutch in frame,you had better line the cavity with towels and what ever,if you drop a a shim,washer or bolt in that cavern you will understand what I mean.....
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 10:09pm
   We used a carpenters utility knife "box cutter" to separate the shims. Works like a charm.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2017 at 5:43am
You do not need to split it to work on the shims.  Remove the battery box and the humped cover and you will have access to the hand clutch.
AaronSEIA
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2017 at 7:17am
45 had a shim pack plus a spacer. After all shim have been taken OUT, replace it with a new shim pack.
Yes, the plates are getting pretty thin.   MACK
