7030 pd trans.
Ed&Sherry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed&Sherry Quote  Post ReplyReply Direct Link To This Post Topic: 7030 pd trans.
    Posted: 18 Jun 2017 at 4:11pm
friend stopped in,asked why his 7030 with a pd locked up while in hi, but he shifted to low and it seemed alright,,is it just a matter of time and lo will also lock up  ?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 6:47pm
No, two shafts seized to gather in front of transmission.   MACK
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 10:01pm
Are you talking about the high low range lever on the right hand side or the power director buttons on the floor?
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 3:10am
If the power director shafts seized together then it wouldn't turn in high or low.  Did the high low range lock up, or the power director lock up in high.  The power director only locking on one side, I wouldn't know off hand how that could happen unless the two driven hubs in the clutch pack got messed up.  I haven't had the range portion apart before to know how that works for sure to offer any guidance there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 7:22am
Most of the time, when the Power Director shafts weld themselves together, the low side shaft twists off. So, when you drive the tractor, it is always in high range regardless of where the buttons are placed....... been there...dun that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed&Sherry Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 9:47am
asked more ? ,,,he says the lever in HI locks up trany,,,lever in LOW can use just fine and both buttons work in low
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 10:00am
Range transmission seizure.  Complete teardown of the rear end and torch the gear off of the pinion shaft...a pretty big deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 10:01am
Not sure what "locks up trans" means...that range shift is in the rearend behind the transmission.Sounds like somehow the range gets caught in both hi & lo when in hi position.
DrAllis,what causes shaft welding in PD's?Low oil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed&Sherry Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 10:24am
will a 7060 rear bolt up to a 7030?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 10:32am
Will bolt right up, but maybe a couple of hydraulic lines are different. Must be a Power Director 7060 to get correct gearing.  Power Director transmission hollow input shafts that seize together can be bearings getting loose from wear and low oil or combination of the two.  Range trans seizure is different and doesn't happen a lot but is catastrophic when it does occur.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 9:35pm
Dirty oil is a big cause for both PD and range gear to seize. Never saw either to happen on any ones tractor that kept oil clean. Fill tube loose in range transmission can get a lot of dirt in one. Operator pulls dipstick, tube comes out and dirt that is piled up around tube falls in. Plus there is a gallon of oil in range transmission that don't drain out when drained unless you suck it out through fill tube. MACK
