Rear End Sight glasses?
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Topic: Rear End Sight glasses?
    Posted: 07 Jun 2017 at 1:26pm
Is there a good place to get these sight glasses?  I have one that is loose and won't tighten.
- Roscoe.
702653592SIGHT, glass
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 1:58pm
Agco had them a few years ago. They take an o-ring to tighten and seal.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 5:04pm
yep....replace the o-ring and you should be good to go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 7:46pm
is this a button glass that fits in a pipe thread hole ?  Aftermarket has 1/2- 3/4 - 1 inch etc
Edited by steve(ill) - 07 Jun 2017 at 7:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 4:34am
Glass threads are stripped.  I'll check AGCO.
Thanks all,
Roscoe.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 7:52am
minnpar.com has them for $16.28. I got some from a salvage yard.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 7:06am
So do the sight glasses help you check out Rear Ends?
Couldn't help myself....Evil Smile
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 7:22am
sight glasses for rear ends.............how about fronts
Wink
I am a Russian Bot
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 9:30am
Here's what I have found with the sight glasses over many years of work on equipment.  In the picture the ones on the left are GM #12475420, they were used for radiator sight glasses in heavy GM units.  The problem with those is they are plastic and over the years they turn white, the replacement has a brown color to it and seems to last longer.  Problem with that is hard to see light oil in it.  The middle ones are AGCO #70265359, glass but the threads do go bad if over tightened.  The one on the right are Case/IH # 427708C1, same as AGCO, mostly found in school bus units.  All of them have the same threads, I like the plastic ones to have around in case I break one or one falls out in the field.  Glass is the best for visibility but the plastic has more threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 12:55pm
It doesn't take much for tight to keep them from leaking with the oring.Too many think they must be TIGHT! and that's what kills the threads.
This page was generated in 0.172 seconds.
