190 lift arms |
acplowboy45
Joined: 09 May 2013 Location: connersville IN Points: 264 |
Topic: 190 lift armsPosted: 26 May 2017 at 4:38pm |
Having problems with the lift arms staying up...just recently pulled the hydraulic remotes out and replaced one of the units...I know there is a screw on top of the units to set lift arm controls. Is there something else I'm not doing to get the arms to stay up.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 26 May 2017 at 9:47pm |
check the traction booster linkage
MACK
Posted: 26 May 2017 at 10:28pm |
Fit of spool to body is all that keeps arms up. A loose fit will let arms down quicker than a good fit spool.
I was told years ago by a AC service man when I ask the same question (the system is a lifting device not a holding device). MACK |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3556 |
Posted: 26 May 2017 at 10:36pm |
some early units had a rate of lower screw, the other screw is a high volume bleed of screw that is a draft assist. As Mack sez neither has anything to do with light arms staying up - You either have a cracked 3 pt valve, a pitted spool or leaky / line/cylinder. IF no leaks, you have two choiced - replace the 3 pt valve or use the position control to keep them up.
