duals
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: duals
    Posted: 17 May 2017 at 7:03pm
With my 8550 down for the count, I've been resurrecting an old 24 foot concord air seeder to put behind my 7060 to try to get some seeding done with that. I took it out for a little test run this afternoon, and it handled it pretty good, but I was thinking that I should slap the duals onto it that I have for my 8070. But I realized that the rears on my 7060 are radials, and the duals are bias. Is that a problem. ...? Thanks, Darrel
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:03pm
We do it also on our 7045. It will ride rougher. Usually bump up the psi on the radials but have had no problems.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:26pm
We have put bias duals on with radial tires. We just lowered the pressure on the duals. I took them off two weeks later since we didn't need them any more. At harvest when we dual end up again we put the correct set on. The sprayer and four tractors all use the same duals and the spare set are bias off a tractor that's long gone. The tire stack got rearranged when we moved it. I don't know if would make a differance long term. Even mix matched sets work some tires have enough wear that there is a diameter differance. Except for the articulating tractors the duals only have about half the tire pressure of the main tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 11:09pm
both my 7080 and 2290 had the duals on like that. worked just fine!
