190
showcattle75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Topic: 190
    Posted: 17 May 2017 at 2:06pm
Hey all I got a problem with my temp guage or sending unit or something else. My sending unit is a year old and I bought my guage at the same time.when the tractor is cold that gauge moves up and pegs hot. I disconnect it from the temp gauge amd it goes cold. What could be the problem.
Thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 2:07pm
sounds like the sending wire is rubbing on something and grounding it.  that is how you can test a gauge to see if it works,  ground the wire.  if it pegs the gauge is good so your sender would be the problem.  in your case the wire is grounded. and ususally with a bad sender the gauge wont move at all
Edited by CAL(KS) - 17 May 2017 at 2:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 2:12pm
I tried a new wire from semding unit to gauge still pegs hot
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 3:00pm
If the dash gauge goes down to cold or below when you unhook the wire at the temp sender it sounds like the sending unit is bad. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 3:42pm
Ya when I disconnect it from the sending unit it goes cold
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 3:47pm
Is the sending unit matched to the gauge?  Put an ohmmeter on the sending unit and watch the resistance. Let me know what it reads as the tractor warms up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:49pm
In iowa and raining right now ill kwt you know
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:28pm
Go to local auto supply and buy a manual gauge. Then you will know what the temp. is.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 10:21pm
Hookedtemp gauge back up with tractor cold. Gauge readeds cold as the tractor warms up the gauge moves then will go red
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 8:01am
Is the temperature gauge grounded? My 220 did that when I put a new gauge in it. The agco dealer told me to ground the gauge. It worked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 2:53pm
The gauge is grounded
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 9:15pm
I pulled sending unit out and boiled a pot of water to 180 and it crawled all the way to the red. Tried it on a different gauge and it did the same thing
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 9:16pm
MACK where would I put the prob at. I have a manual gauge and can't find a coolant spot to put it
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 10:06pm
 It really sounds like you have the wrong sending unit for the gauges if it did it to two gauges.
  Hate to say this but you should do what Doug told you to do....
 " Put an ohmmeter on the sending unit and watch the resistance. Let me know what it reads as the tractor warms up" .
 Do that and report back. OKay?
  Or go back and get another sending unit, and hope it's the right sender... not just a duplicate to what you have... but the correct one.
  Need to find the ohms the gauge works in and a sender that works in that range.
This page was generated in 0.168 seconds.
