7030 not getting fuel |
chaoticfields001
Topic: 7030 not getting fuelPosted: 10 May 2017 at 5:17pm |
I recently purchased a 7030 that has been sitting in a shed for several years.
Got it home drained the fuel put new fuel in changed fuel filter cracked loose the fuel line to the injection pump and used primer pump to get fuel to that point. Then cracked loose fittings on injectors 2-6 couldn't get #1 loose so loosened it at pump cranked engine but no fuel seems to be getting through pump any ideas or suggestions ?
DougG
Posted: 10 May 2017 at 6:17pm |
Setting is a bad word on diesel fuel these days, take a flashlight and peek in the tank, if I have trouble with one like you describe I start st the tank, clean it if it needs it, then on up to the pump, the Roosa a,s can take alot but gotta have good fuel, I think those had a lift pump, is it working?
Edited by DougG - 10 May 2017 at 6:24pm |
MACK
Posted: 10 May 2017 at 9:23pm |
Metering valve stuck or plungers are stuck. Remove top cover, there is a valve under cross shaft. Work it back and forth to free it up only if there is fuel around it. If that don't it, might as well send it to pump shop. MACK
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8752 |
Posted: 10 May 2017 at 9:57pm |
....and set the timing marks together BEFORE removing it!!
