34 WC engine block
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: 34 WC engine block
    Posted: 25 Apr 2017 at 9:08pm
I disassembled a 1934 WC engine to a bare block. the block doesn't have any cracks in the top or bottom, but has a freeze crack on the side. If you want the block come get it. It is on my iron pile now.
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 10:21pm
Any idea what the serial number is  and what casting number is
Edited by Gary(WI) - 25 Apr 2017 at 10:22pm
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 11:23am
I don't need the block but I would like the dash number for the casting and engine serial number and if possible the serial number of the tractor it came out of for my chart I am building. So far I only have two from 1934 blocks:
U 3019-2     W312
U 3019-3     W1835
http://www.allis01.com/fossto/AC-WC-Engine-Data.html
Edited by TomMN - 26 Apr 2017 at 11:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 12:35pm
I am interested if it is the right number range
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 1:29pm
The casting number is U-3019-3
Serial number is W1839
Edited by Lon(MN) - 26 Apr 2017 at 1:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 9:42pm
Thanks, it has been added to the chart.
Randy MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 1:05pm
Tom,
My 34 WC has casting # U 3019-3 and engine # 475.
34 WC #477, 38 B #1935, 1-116 on steel, #8 7ft dbl action disc, #9 5ft dbl action disc, 295 Chainsaw
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 3:01pm
I've recently gotten a 1936 WC in my shed.  Where are the casting number and engine serial number located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 4:17pm
The casting # is on the block under the oil filter and mag. The engine # is facing rearward on the block just in front of the clutch inspection cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 12:17am
Thanks Randy, I have yours added to the chart.
This page was generated in 0.168 seconds.
