170 and wd value?
dewn81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dewn81 Quote  Post ReplyReply Direct Link To This Post Topic: 170 and wd value?
    Posted: 24 Apr 2017 at 6:30pm
What would the value be of a 170 gas that is very rough but is complete and In need of a engine overhaul? Aslo what is value of a wd that is rough and complete but it doesn't run?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 9:09pm
Very little for both.  They are both rough and not running/need rebuilding, your best bet would be to either part them out or send them to China.  If they weren't rough, I would probably rebuild the engine. and go from there.  No more than $1000 for the 170 and $250 for the WD.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 9:35pm
Depends tires pretty good? or shot? Have to start looking at what the pieces are worth also depends if you do engine over hauls yourself or hire it all done.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 6:33am
'bout right on the WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 7:25am
And if the One-Seventy is a runner, take it down a steep hill in 3rd gear high side at full throttle and cut back fully on the throttle to see if it jumps out of 3rd gear. That long shift lever was a bad idea, as it allows more grinding of the gears by an abusive operator.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 7:25am
You can fix a broken tractor and you're good to go,with a worn out one repairs never ends.
