WD 45
Dads 45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dads 45 Quote  Post ReplyReply Direct Link To This Post Topic: WD 45
    Posted: 14 Apr 2017 at 9:33pm
No working lights on my "new" tractor so had Brenda at Sandy Lake send me a new switch as had no juice coming out of the old one.
Swapped it and got juice flowing again but still no lights.
Took the ring off one headlight and it had a new light/reflector/bulb assembly already.
Had a blown 1129 bulb. I stuck an 1156 in it for now and got light.
Hafta say I was surprised it didn`t have a sealed beam bulb. Is this normal lighting for this tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 10:11pm
Yep, these oldies do not use sealed beams.  Those started with the D14.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dads 45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 10:14pm
What bulb is recommended?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 10:18pm
Depends if you are running 6 or 12 volts.  Switched my 1954 WD45 to 12 volts a couple of years ago.  Just took the old one to Napa and said "Give me a couple of these in 12 volt".  Can't remember the number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dads 45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2017 at 10:19pm
I just read the 1129 is the 6V version of the 1156.
Thank you!
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 11:11am
We have sealed beam lights on our 45 It is a standard light, nothing special.
