|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Cracked exhaust manifold 190 gas |
| Post Reply   |
| Jamz   Bronze Level     Joined: 02 Jan 2017 Location: Wisconsin Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Topic: Cracked exhaust manifold 190 gas Posted: 10 Apr 2017 at 3:28pm |
   I can not find a replacement exhaust manifold for my 190 gas, it appears they aren't available NOS, aftermarket, or used and from the sound of it, I wouldn't want one anyway because they always crack. One crack had been welded and didn't hold.. I think I can clamp a soft aluminum gasket around both cracks and install new manifold gaskets(readily available) and be OK. Or, perhaps others in this situation have found better a solution ? I would like to replace the intake manifold gaskets also because I think they're leaking and causing it to run rough after an hour or so of proper operating temperature....but I cannot find them anywhere. Can anyone help me find them ? It's an early 190, sn# 1364 if that matters. Thanks Edited by Jamz - 10 Apr 2017 at 4:11pm | |
| farmboy520   Orange Level Access     Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |  Post Options  Thanks(0)  Quote  Reply  Posted: 10 Apr 2017 at 3:52pm |
   Do you have one? Are you wondering if you can fix one? What are we dealing with? We want to help you. Edited by farmboy520 - 10 Apr 2017 at 3:53pm | |
| Jamz   Bronze Level     Joined: 02 Jan 2017 Location: Wisconsin Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 10 Apr 2017 at 4:16pm |
   Sorry Farmboy, I fat fingered and sent the post before writing it,  it should be updated now. | |
| 45 turboa-   Orange Level     Joined: 04 Feb 2012 Location: coral city wi Points: 441 |  Post Options  Thanks(0)  Quote  Reply  Posted: 10 Apr 2017 at 4:22pm |
   I have one off a 180 gas I think it is the same i'll CK part # to be sure.
     turbocharged
| Jamz   Bronze Level     Joined: 02 Jan 2017 Location: Wisconsin Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 10 Apr 2017 at 4:51pm |
   Part# on my cracked one is 4023626
| LeonR2013   Orange Level     Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |  Post Options  Thanks(0)  Quote  Reply  Posted: 10 Apr 2017 at 5:18pm |
   They can be welded, but it takes a man that knows what he's doing. If your intake is not cracked they can be surfaced.
| ac fleet   Orange Level   Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |  Post Options  Thanks(0)  Quote  Reply  Posted: 10 Apr 2017 at 8:17pm |
   What about one off a combine engine??? different OR same??? thanks; ac fleet
| Matt (Jordan,MN)   Orange Level   Joined: 12 Sep 2009 Location: Jordan, MN Points: 3808 |  Post Options  Thanks(0)  Quote  Reply  Posted: 10 Apr 2017 at 8:43pm |
   Have a nos one for sale. Send me a PM if interested
     Owner of Matt Scott LLC Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ | |
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 11 Apr 2017 at 7:24am |
   A new A-C replacement manifold is probably different than the original. A-C took out some of the sharp bends in the runners to help keep the cracks from forming.
| Calvin Schmidt   Orange Level     Joined: 11 Sep 2009 Location: Ontario Can. Points: 4555 |  Post Options  Thanks(0)  Quote  Reply  Posted: 11 Apr 2017 at 10:28am |
   When I was looking for one last year, I found that there are 3 part numbers each superseding the previous one. I bought a nice properly welded used one and had it resurfaced before instalation which is a must in my opinion.
| AndrewGubbels   Orange Level   Joined: 12 Sep 2009 Location: nebraska Points: 1517 |  Post Options  Thanks(0)  Quote  Reply  Posted: 11 Apr 2017 at 10:44am |
   The combine manifolds will work and as was stated earlier in multiple posts the later ac manifold was redesigned without allis chalmers written on the exhaust side. The later g gleaned and we also have a 1970 190xt gas with the later style. They do not have the issues breaking. Also definitely have it surfaced or be checking this. I like to do the exhaust and intake together bolted up so there is as little chance of a bind as possible.  Andy | |
     Andrew Gubbels Gubbels Restoration | |
| Jamz   Bronze Level     Joined: 02 Jan 2017 Location: Wisconsin Points: 24 |  Post Options  Thanks(0)  Quote  Reply  Posted: 11 Apr 2017 at 5:59pm |
   Thanks guys, this is good info !   It may explain why ALL STATES parts catalog does  have an item(101486) that replaces OEM no. 74007652 and 74007653. No mention of my 4023626. However, the picture they have of that item definitely does not look like it would work, it has the outlet square in shape being off center while mine is a round threaded outlet that's centered. Maybe it's just the picture in their book that's wrong. If anyone knows what part number(s) the newer ones are, I'd appreciate it ! Or if the one from the combine is the later style.... and if so, has the same part number. | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
