Pitman arm for B/C Sickle Mower |
MilesGray (CO/KS)
Orange Level Joined: 13 Sep 2009 Location: CO/KS Points: 729 |
Posted: 30 Jun 2010 at 12:16pm |
I need the dimensions for the Pitman arm so I can make a couple for my broken ones. Could someone measure one for me please?
TIA
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
MilesGray (CO/KS)
Bump, still need this please!
Miles Gray (CO/KS)
BrettPhillips
Orange Level Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
Miles: It is important to know what style pitman you have. The early style used a ball swivel that clamped over the knife head ball with a bolt, nut, and leaf spring setup, while the later style used a coil spring that fit in the end of the pitman to hold the swivel halves tight on the knife head. The early style is the simplest, and you could probably work out the correct length with some careful measurements of your mower, and after that it wouldn't be hard to make up a pitman that would work just fine. The later style might be more sensitive... |
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6353 |
I'll try and remember to measure mine tomorrow
Charlie
MilesGray (CO/KS)
This is the type of sickle mower I have, it does not have the bearings on the ends.
7 foot mower.
Thanks, Miles Edited by MilesGray (CO/KS) - 07 Jul 2010 at 8:30pm |
Miles Gray (CO/KS)
Bud(WI)
Bronze Level Joined: 12 Sep 2009 Location: Wisconsin Points: 68 |
Miles,
Have a look at http://www.oldengine.org/members/steinich/ click on the Pitman Pictures link. Dave |
Roger Mn
Bronze Level Joined: 12 Sep 2009 Location: Preston Mn Points: 98 |
You can buy them at tractor supply Roger Mn
BrettPhillips
Miles: I'm confused by your reply. Do you mean that you have none of the hardware that bolts to the wooden stick, or do you mean to say that you don't have a twin wheel drive mower that uses ball bearings in the pitman? Here are pictures of the early and late style pitmans that used wooden sticks: |
pumpkin man
Silver Level Joined: 10 Apr 2010 Location: Michigan Points: 106 |
Looks like all you need is the wood pitman blank tractor Supply has them T S C stock number is 1206405
MilesGray (CO/KS)
Thank you all for your responses, I do have all the parts just not the wooden pitman arm.
Miles Edited by MilesGray (CO/KS) - 09 Jul 2010 at 8:27am |
Miles Gray (CO/KS)
Charlie175
Sorry for the delay.
Mine is 26" long x 1 1/8" x 1 3/8" |
Charlie
