Hydraulic Oil Question |
MikeinArk ![]() Bronze Level ![]() ![]() Joined: 27 Apr 2010 Location: Searcy Arkansas Points: 31 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Jul 2010 at 9:49am |
Have early 1957 D17 What hydraulic oil is best for the system? Standard tractor hydraulic oil?
1957 D17,1973 Mustang Mach I CJ, 1984 Mustang anniversary Conv, 1966 Thunderbird, 1978 Mustang Ghia, 1974 Ford F100 Ranger
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Haave been using universal trans-hyd fluid in my D14/15/17 for several yrs with no problems.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
BobHnwO ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
I get hyd.fluid from TSC,meets all manuf.specs.
Thanks
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
When we sold them it was SAE 20 NON DETERGENT oil. Worked well. However, I have heard very good reports of the trans-hyd fluid. I am now a convert.
Good Luck!
Bill Long
I guess I will need some good luck. Topped off the fluid lift arms won't move. With tractor running has a noise coming from pump area. It is either the pump or the ram cylinder or both. Trying to figure out what to check first.
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9733 |
Check the oil level again.
If the hose which runs through the rear end is broken, it will fill your transmission with hydraulic oil. |
If you end up having to replace the hose, buy the hose from AGCO. There is a stripe on the side of the hose. When installing the hose, DO NOT allow any twist to the stripe.
You tractor has a high pressure low volume hydraulic system. The everyday run of the mill hydraulic hoses are not strong enough to handle the pressure. While you have the rockshaft housing removed, it is a good time to replace the lift cylinder O-ring and the two back up rings. |
Thanks Clay
I will have to check it out this weekend
