New to me Model D Identify please
TurboTexas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Topic: New to me Model D Identify please
    Posted: 15 Jan 2017 at 10:07am
I stumbled onto a Model D, and I'm not sure how to figure out what year engine etc.
I tried searching, but I kept getting rejected for the 3 letter minimum!
Now I can't load photos from my iphone6+!
Too large of a file size...
Pretty lame I can't get any help here!!
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 10:36am
You have to edit the size of your picture to shrink it down. On the left side there should be a serial# stampd on the flange where the engine bolts to the tranny/torque tube.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 1:37pm
If you are referring to a D Grader the serial number would be on a plate riveted to the frame where you climb onto the grader. The number should start with a 'D' followed by 4 numbers. Post these numbers and someone on this site can tell you the year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 7:03pm
Where can I find info on fluids, capacity and types?
I've already changed the engine oil!
Looking for where you fill, where the levels need to be, what weight of lube for chain boxed and the tranny!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 7:06pm
You haven't said what you have yet. Is it a D grader or a D series tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:01am
My apologies, it's a Model D grader
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:02am
Any suggestions on a .jpeg size reduced that works well with an iPhone??
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:09am
This is no help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 6:01pm
Grille looks like the '52 D, in norm's construction book. It should have a wd 226 c.i.motor, either that or it could have a 201 from a wc if someone swapped one in.  I'd take some gentle paint remover, to that aluminum tag, and use a scotch brite kitchen pad, and gently brush back the orange paint, to see if the stamped numbers are still there.  Could be that some idiot sandblasted everything away, before that last orange hosing.  There could also be a block number, up above the carb, on top of the block, near the VC gasket surface.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 6:05pm
On second viewing pf the pix, it looks like a D special, with the leaning front wheels, power angle, etc.  What size are the tires?Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 6:26pm
The tire size is 8.25 20
This has the power circle and yes the tires lean!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 7:09am
Is there an online manual to these? I'm still needing to know what kind and capacities in the fluids department!
Or is there a way to search on here without the 3 letter block kicking in?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 7:57am
Looks like you have a real gem there, Turbo Texas. Looks sweet. Unfortunately, I won't be of any assistance to you on it, but be patient, and information will come. Like another said, try removing the paint from that serial number plate, and hopefully the serial number will show up. Traffic is a little slow here on the construction side of the forum, but some knowledgeable people will show up for you with the information that you need. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 9:01am
Frustrating that I can't find any info on a simple thing like fluid changes?
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 12:21pm
The wheel hubs appear to be (non-D Special) equipment. Grill is the late style grill usually used with the square tube machines.
Curt Anderson
HD3, HD5B, HD6E, HD6AG,HD6B dozer, I-400, 615, 616,(2) 620, 720, ACP25 lift truck, 1956 D Special Grader, AC 540 loader, AC 655 crawler loader, AC #84 plow, Simplicity lawn tractors.
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 4:10pm
Hi.   General information:   I am still having problems with 'sizing'. I hope you can glean some information from this article that will lead to you being able to get the information you require. There are certain items that appear to have been changed, added, or deleted. Example: the power steering was never installed this way by A.C., although they used some Behlen rotation units on some of the steering columns.
Sorry, all my manuals are back at my shop in Ontario; or, I could look up some of the details that you are asking about. We are currently in Florida.      Ross D.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 5:51pm
Thank you for the bit of history! Enjoy your warm winter! I'm from South Texas, and I grew up seeing "Snowbirds" come and go!
I can't blame ya for wanting to get out of the cold!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 6:03pm
Look for that number, on the head, it may be traceable, and may tell you if its a wd motor.  If so, engine data will be the same as for a wd  tractor engine, as far as specs and capacities.  does it have power blade slide?  If so, it is a d special, to spite what the decal by the seat says...Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 6:05pm
on edit:
Looked at pix, again, no power blade slide, so its just a D...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 6:30pm
I'm not sure what a power slide is?
The engine oil has been changed, with a 10/30 and Lucas oil stabilizer!
Now I'd like to drop the fluids in the transmission, & the two chain boxes!
I would also like to replace all the hydraulic fluid out to new! Just so I know everything's right!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 7:10pm
Hi again.    Serial number location !
   Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 7:23pm
shrink to fit
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 10:12pm
   Ross.
I posted a photo... someone got carried away with the paint! :(
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 10:13pm
   Ross.
I'd love to find the ripper attachment!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 5:52am
powerslide  allows you to move the blade about a foot to the left or right, hydraulic-ly...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 7:38am
Actually I believe it has that option? 5 total hand controls...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboTexas Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 7:39am
So what kind of oil do I put into the chain boxes?
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 2:51pm
Well the AC 45 book says above 32 F SAE 50 engine oil
FWIW
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 5:49pm
I used 90 weight in the D we had.
Ya cain't fix stupid.
This page was generated in 0.048 seconds.
