Loss of power B
ihscout View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Topic: Loss of power B
    Posted: 15 Dec 2016 at 6:30pm
My 40 B all the sudden lost a lot of it's engine power yesterday. It sounded as though the exhaust system is clogged somehow. I pulled the intake / exhaust manifold and found a couple of cracks in it. Welded those and reassembled. No change. Any ideas as where to go from here?
'40 AC B - My Pappy always told me "Use your head for something other than a tack hammer!" I did. It makes a great 16 pound sledge hammer.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 6:50pm
Is it hitting on all 4 or you missing spark on 1 plug.  Check for good fuel flow at carb.
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 7:03pm
check your air filter may have a mouse nest or some other thing plugging it up. Randy
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 7:36pm
I do not have all the particulars but usually when a tractor loses power under load my first suspect is - cheap, the condenser, more costly the Coil
Can't have my favorite not running well.
Let us know how it goes.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 7:57pm
It is hitting on all 4 cylinders and the air filter is clear. I just put a newly rebuilt magneto on it this summer and have very few hours on that. It doesn't reach the higher RPMs as it did a day ago. Would the governor have anything to do with it?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 8:30pm
Originally posted by Would the governor have anything to do with it?
[/QUOTE Would the governor have anything to do with it?    [/QUOTE wrote:
You could disconnect the rod to the carburetor and manually throttle up on the carburetor linkage itself to see if that makes a difference.
Edited by Eric B - 15 Dec 2016 at 8:32pm
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 8:32am
Could also check to see if your mag bolts came loose and the magneto rotated. If the timing adjustment you can do by rotating the mag gets off and retards the timing it will seem like its lugging or loaded at full throttle even when its not.
This page was generated in 0.110 seconds.
