Foot clutch symptoms
Pete32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Topic: Foot clutch symptoms
    Posted: 12 Dec 2016 at 3:01pm
I was hoping someone could chime in to explained what could be wrong with my ac-wd. Here are the symptoms:
I can use the foot clutch to stop the tractor and shift gears. When I let the clutch out, the tractor will move briefly forward or backward (maybe 6 inches) and then stop and won't go any further. I've tried repeatedly pressing the brakes and nothing happens. I've greased the throw out bearing. I then have to pull back the hand clutch to get the tractor to go. Also, the free play is currently at 1 3/4 inch. I haven't had much time to work on it. Could the excessive free play cause this, or is something else going on? It works fine with the hand clutch. Thanks. I'm new to tractors.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 3:17pm
That's how the tractor is supposed to work. These tractors have 2 cluches to give live PTO. You must release the foot clutch and pull back on the hand clutch to drive. If you push on the hand clutch the tractor will stop but the PTO will keep turning. (But the reality is that usually the hand clutch drags a little, and you have to push the breaks a little to stop the tractor when the hand clutch is released.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 3:38pm
Dave is right on the money! Your tractor sounds like it is working as it should.
We now need some pictures.
Most of the time I have to push the foot clutch in to get the tractor into a different gear.
Doing that stops the hydraulics and PTO and forward motion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 3:43pm
LOL, I'm a total rookie. Thanks guys. My worries are over!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 3:47pm
Pete,
 Welcome to the forum!
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 6:08pm
And you should always use the foot clutch to change gears. Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 8:55pm
Since you are new to the tractor, I strongly recommend getting an operator's manual for  the tractor.  It will tell you everything you need to know about it.  Manuals are readily available on e-bay and some vendors here carry them.  They don't cost much and they are a wealth of information.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 11:10pm
You thought applying the brakes would help it to move?
