adding gas to diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: adding gas to diesel
    Posted: 29 Nov 2016 at 5:21pm
OK, as most know I have an 'special, ultra low compression' Buda diesel in my A-C forklift...someone told me to try adding some regular car gas into the diesel to help it start.
Currently it needs 3 squirts of ether to get her going,runs on 2 1/2-3 cyls then all 4 fter 2-3 minutes.
Figure I'd ask the experts here before I try it !
Jay
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 5:26pm
Don't mix gas into your diesel fuel!!! We had a 55 gallon barrel of mixed diesel gas here when I was a kid. My uncle claimed that someone put gas into one of the diesel tractors here and it separated sitting over night. Blew the motor the next day when a slug of straight gas went through.   Took use years to figure out how to properly dispose of the barrel of mixed fuel that was left.
It all happened before my time I just remember trying to find someone who would take the mixed fuel for disposal. Finally found someone who had a bunch of gear oil he wanted to run through a waste oil heater he took it to mix in there.
Edited by Dan73 - 29 Nov 2016 at 5:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 5:31pm
I your having a starting problem it's not the fuel but either the pump or low compression .
 As for mixing gas with diesel - it is done to lower #2 fuel to #1 so as not to jell- about 1 gallon per 20 gallons of #2 - for use in cold climate in emergency - NOT FOR NORMAL USE .
 So you may have bad injectors , bad pump , timing , or low compression - check all those before doing a voo-doo fix with mixed fuels
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 5:33pm
hmm never thought about the 2 separating and the lift sits quiet most of the time....
OK, so NO gas...
what about 'additives' or def  ? anything to help her start and run ? she is a 'challenge' to get going once Old Man Winter appears.....and no I still don't have 5K for a rebuild....
I generaly wait until 2-3 jobs need to be done,then use it.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 5:37pm
Add one of the heaters you put into the coolant system once you heat the block up it will start easier.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 5:41pm
Raising the cetane number will assist in starting more than adding gasoline. There are several cetane boosters on the market, but I'm a bit skeptical. Buy high quality fuel and fix your other issues if that doesn't do the trick.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 5:53pm
Have you got a plug in heater?
I would think that thing would be happier if you fed it something like WD 40 to boost the start.
JIMncMO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JIMncMO Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 8:05pm
The light distillates that gasolines are made from have a natural high-octane index. The middle distillates that diesel fuels come from have a high cetane index. The octane and cetane indexes are INVERSE scales. A fuel that has a high octane number has a low cetane number, and a high cetane fuel has a low octane number. Anything with a high octane rating will retard diesel fuel's ability to ignite. That's why each fuel has developed along with different types of engine designs and fuel delivery systems. Gasoline mixed in diesel fuel will inhibit combustion in a diesel engineand diesel fuel mixed in gasoline will ignite too soon in a gasoline engine.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 8:14pm
Does it have glow plugs? The not running on #4 right away seems like the cylinders are just too cold to start. A block heater would go a long way for sure.
Edited by Bill_MN - 29 Nov 2016 at 8:14pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 8:37pm
Save the gas for your D14's. lol The old Budas use one intake heater not glow plugs. You can get away with using #1 fuel in a light engine load like a fork truck is. I'd pull the injectors and have them tested first them look at the energy cells next. Yes a good block heater is best.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 9:30pm
OK, so NO gas...
Jay
Whatever you do, don't add DEF. All that is is urea and water and will pretty much ruin all fuel related items, including the injector pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 9:47pm
Funny DEF pretty much ruined all my intrest in a new diesel engine.   Makes me want to keep the old ones running....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 9:52pm
My car uses DEF. No big deal. It uses about 2 gallons per 15,000 miles. It costs about $8.00 for that amount at Wally World. It beats the heck out of EGR, which robs horsepower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 9:55pm
Still scared of any system that is designed to freeze up near zero. To many 20 plus below nights here for me to think adding a liquid that freezes to a car is a good thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 11:13pm
First and foremost, gasoline will not blow up a diesel. I've pumped out far too many diesels that were filled a BP station because they refuse to use industry standard colors for pump identification. While it is a dirty thing to do to the high pressure side of the system, there are not enough BTUs in gasoline to run the engine on the amounts injected. The next one is since gasoline is thinner than diesel, developing enough pressure to inject is a challenge. In small amounts gasoline can cause serious wear on the pump and injectors.
NEVER NEVER NEVER NEVER NEVER put DEF in the fuel tank. I did say NEVER right? City of Newton Iowa did that to one of their ambulances. It died on a run. Cost them about $16,000 for me to replace every metal part in the fuel system. Pump injectors all fuel lines. DEF is extremely corrosive to metal parts.
If you accidentally do put DEF in the fuel tank, DO NOT START THE ENGINE! A tow bill and cleaning the fuel tank is a whole bunch cheaper than the alternative.
DEF is 33% urea 66% water. It freezes at about 12 degrees. It's used in conjunction with the selective reduction catalyst to reduce oxides of nitrogen or NOX. DEF systems have no negative impact on engine performance as EGR does. The EPA mandates programming to force you to keep DEF in the tank and the system working. They have clamped down on programmers that eliminate aftertreatment systems so they're not as easy to get anymore.
Since DEF freezes, there are electric tank and line heaters. The only exception I know of in the automotive world is Chrysler tried to use engine coolant the first year or two on Ram chassis cabs. It worked very well to thaw the frozen tank, but heating the DEF too much causes it to quickly break down and become ineffective.
Edited by Brian Jasper co. Ia - 29 Nov 2016 at 11:19pm
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 1:44am
i'm with Dan on keeping the old ones running!
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 6:08am
I knew I was behind when I saw the "DEF" in a post above.
Sooo,,I googled it.
http://www.discoverdef.com/def-overview/faq/
seems like a person has to buy more and more to make something work!!
Edited by JoeO(CMO) - 30 Nov 2016 at 6:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 6:27am
hmmm interesting about DEF...
sure be a nice way to stop 'kids' from 'borrowing' cans of gas at midnight.......
NOT that I'm saying to do this.....but if you mislabelled or misjugged some DEF.....
back on track.....
Even WITH the lift 'up to temperature', mid summer, it still needs a squirt or two maybe 50% of the time which kinda says a block heater probably won't help .
Still looking for the right low budget 'bandaid',only use maybe 2 gallons of diesel a month....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 6:35am
Heat will help. Won't fix a tired motor but the cold is why you can't start it in the winter but can get it to start in the summer. If you want to get it to start right you have to rebuild the motor Jay. Sorry no magic fix for a tired motor....
Brent.eggers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brent.eggers Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 6:47am
Either is cheap it's meant to start engines you mainly have to no how strong you are applying it without either the world would be a very bad place. If your scared use a little Weeker brand their is strong & week either .
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 7:38am
I have seen worn out but lightly used diesels limped along for many years by using starting fluid. One of them sits right outside my office door in an old Case fork lift that gets run for 30 minutes a week. Another one is a W11B loader at my place. I would just keep using the starting fluid, obviously you are smart about using it.
 People ruin engines with it when they spray a continuous stream in the breather until the engine fires. Smart people realize that it takes a few revolutions for it to be drawn in and don't do that.  You can also save the starter a bit by installing one of the kits with a 1/8 line going into the intake.
 When I start my old Case I get it a shot and if it is missing it gets another little shot to get it going on all 4.  I was told years ago by an experienced CAT mechanic to do that and NEVER let a diesel run along missing until it warms up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:36am
Interesting that DEF should come up and the following is worth passing on.
Take from it what you want, it was overheard or relayed to me.
Was riding with a fella that has a GMC Duramax 4x4 double cab, 2015, fully loaded with everything he could order on it seems (never seen "full leather" cover so much of the interior on a pickup before).
He receives a call from his buddy at the dealership telling him they want the truck and will give him 48K on trade for a new fully loaded 2017 GMC Duramax and he replies he would have to think about it as he gave nearly 70K for it and it only had 90K miles on it so just getting broke in (runs back and forth to West Texas constantly). Dealer salesman buddy tells him they have DEF systems causing total replacement of the system coming in weekly and it is tracking between 90 - 110K on miles when they go down, at 3500-4000.00 charge to fix/replace.
I don't think much of it, bought myself a 2007 6.0 2500HD 2WD for the small farm/tractor toy towing a few years ago. Had Cummins with company trucks but all were 2006 or older. Loved em' but wondered how the DEF was going to add to the overall diesel pickup operating costs for folks and would it eventually start pushing some back to gas engines as the diesel option seems to be pushing these pickup costs ever higher.
Three weeks later I am at the shop where I bought my CM bed for my 2500HD as I needed a front grill guard and nerf bars so a fat boy can get in/out easier.
Ask the owner of the shop when he bought the new RAM 2500 double cab 4x4, with a HEMI, as he was always so pro Cummins and had a 2014 model last time I was in over a year ago. He relays his story on the DEF as he had taken his diesel in for a oil change at the dealership when his salesman buddy pulls him to the side and tells him he needs to get rid of the truck as they are seeing units come in for system replacement to the tune of 3000.00 plus, at around 100-120K miles.
He advised he decided to let it ride and it went down two months later. Had it towed in, swapped it for the HEMI and said he will not have another newer diesel.
Anyone else hearing things about this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 10:52am
Read my post above. DEF is not that expensive. I have my car serviced every 10,000 miles and they refill the DEF tank at that time. They put in a little under two gallons. Let's put it this way: They cost of DEF is far less than the cost of what you lose in MPG with an EGR system. The last time I bought DEF it cost me $10.99 for a 2.5 gallon container.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 10:54am
OK..follow up.... tried 3 spray bottle squeezes of WD40.... silent
3 squirts of ether... she starts....yeah, belches a lot of light whitey/blue smoke for 4-5 minutes but once she settles down, runs OK.......
seems the old gal needs something 'peppyer' than WD40 to get her going.....
re:DEF. I heard that if you're driving and run out of DEF and then shut off the truck, it AIN'T going to start again UNTIL you refill the DEF can ! Tell me that wouldn't be 'fun' 50 miles from anywhere,middle of winter, 2AM,....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 10:56am
My concern isn't the cost it is how long can that jug take freezing and thawing everytime I start the truck all winter long. That sounds like a broken system just waiting to happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 11:03am
My car sat outside all last winter without benefit of a garage. It hit a minus 18 on a couple of nights. There were spells when it got down near zero for many days in a row. There was nary a hiccup from anything, including the DEF system. It isn't as if "only a few" diesels run DEF. There are thousands out there and I've never heard of DEF/freezing problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 11:05am
I hope you are right I will give them a about 15 years first to see how time proves it out.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 11:06am
Jay we are using brake clean in our shop for some of the hard starts and cold starts. Seems to work well and cheaper than ether.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 11:57am
The quickest thing I would suggest to starting a diesel without either or plugging it in, would be fire up your propane plumber's torch and stick in in the intake open intake plug. By the time you can get around to the starter button it will fire right off. As said above Gasoline and Diesel are not meant to be mixed. If you don't use it much just run it on Kerosene with a lubrication additive.   Also Gasoline will suspend water easily and a drop of that will blow the tip off of an injector.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 2:30pm
nuther update.
I do have a single manifold glowplug,that works but sure drains the battery down. I was thinking of a 2nd battery,then need to rejig the alternator to recharge both batteries.
suposed to be crummy rest of the week so I may look into that.
ANy idea how long to run the glowplug for? should it be on while starting? Obviously NO ether or 'helper' chemicals .....
Jay
