190 gas snap coupler
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Topic: 190 gas snap coupler
    Posted: 15 Nov 2016 at 11:12am
Would this setup be a collector's item.?..if I found one...what should I pay....kinda looking for one with low hours...Mark'
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 2:35pm
If you were moving up from a D-17, you might think gas engine and snap-coupler on a 75 HP One-Ninety. If you were thinking more acres, you'd buy a One-Ninety XT diesel with a 3-point hitch.
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 4:50pm
we have a lp gas snap coupler 190 with a factory cab its a lot of fun to drive and doesn't use much lp on the grain augers and pulls a 6 ton spreader no problem Niel
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 6:32pm
I have a gas snap coupler 190. I have $2000 into it. I paid $1000 drove it home and put some very used tires on it. Fixed the lights and ammeter. I've seen several on Craig's list between $3500 and $6000. 34" tires are imposable to find used in good condition and the tractors not worth the cost of new ones. If Ihad a use for it it would be worth more but it's a lot of over kill for the 6' mower and towing an empty hay rack around the yard. There mot very fast top speed is about the same as my WD 45.
Hoss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hoss Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 7:29pm
I've got a 190xt gas snap coupler. Got $2100 in it.
I got both ends meetin in the middle but I can't seem to get em tied.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 4:52pm
Thanks for imputs....do collectors consider this a good tractor...or an oddball...would a 180-185 be better or just as good...Mark
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 5:08pm
Myself i'd rather have a 185 than a gas 190 with snap coupler any day of the week. Diesel engine and 3 point are just two reasons. In our area, the price of admission wouldn't be a whole lot different either.
Other than camparible horsepower the two tractors don't really have a whole lot in common though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 5:53pm
Depends what you are doing with it.  If you plan to use it a lot, I would not bother with a thirsty gas.  It is a bit of an oddball, but don't buy it thinking it will appreciate in value because it probably won't.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 8:31pm
I have a OneNiney gas  3 pt and have $1500 before I installed a Narrow Front. Just a toy that I pulled a few empty gravity bins to the field with.  185 diesel would be a better working tractor.
