Rebuild Hydraulic Cylinders CA |
Hubnut
Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Topic: Rebuild Hydraulic Cylinders CAPosted: 21 Oct 2016 at 8:39pm |
Is it hard to rebuild these cylinders? Mine are leaking and I've tried tightening the nut over the "piston" with no change. Who carries a rebuild kit?
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
NICKMI
Joined: 15 Sep 2009 Location: Greenville Points: 534 |
Posted: 21 Oct 2016 at 8:45pm |
Pretty easy job I got mine from sandy lake implement
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7569 |
Posted: 21 Oct 2016 at 9:14pm |
Any local hydraulic shop should be able to get what you need.
Hubnut
Posted: 22 Oct 2016 at 4:51am |
Thanks for the suggestions.
1940 B "Lucy"
HD6GTOM
Posted: 22 Oct 2016 at 9:17am |
I ask on here and got several responses, ordered them for the WD45 off the first fellow that responded. Got them in a few days.
Tcmtech
Posted: 22 Oct 2016 at 10:04am |
As others mentioned most any hydraulic shop will have what you need although if they are by chance some odd ball non standard seal design it may be necessary or at lest way cheaper to have a bit of machining work done to refit a more modern and common seal set put into them.
I've done it a number of times now with old hysraulic cylinders over the years. Most times it was simply due to a hard to find OEM style seal being rather costly, $100+ Vs a common and better designed $10 seal set that could be refit with some simple machining for <$50.
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5147 |
Posted: 22 Oct 2016 at 10:36am |
Got my seals from djs tractor parts and put them in myself. No big deal
