traction booster line
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Topic: traction booster line
    Posted: 21 Oct 2016 at 4:56pm
am I safe to assume that the 1/8" line that goes to the traction booster gauge has full hydraulic pressure on it.
thanks dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 4:58pm
I'd assume that...it's a STEEL line ..good for 5,000 PSIso do NOT use copper or uluminum or plastic.....lol
Jay
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 7:18pm
Yup, Full hyd. pressure . It is just a hydraulic pressure gauge  with a different painted face, nothing special.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 7:43pm
Yup. I have one off of a WD that I'd sell if you need one.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 12:39am
the guage doesn't help you do anything better than without it.Good for amusement but what you feel the tractor doing is your best feed back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 6:55am
thanks for the conformation!
restoring my dads d14, steel line was questionable so i want to replace.
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 11:18am
Tube is NLA from AGCO, might be some NOS around yet.
I like having the gauges working. Even if you are not plowing they are good to have to help diagnose the hydraulics now and then. Just an FYI the gauge measures the pressure on the lift cylinder to let you know how much of the implement you are carrying.
Jim
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 9:58pm
Go to NAPA and buy a brake line to replace it. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 10:30pm
Jim
I always wondered what it did.
Dale D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale D Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 10:12am
I am trying to restore my father's old D15 Allis chalmers. The 1/8 inch line that runs from the traction gauge to the small square block is bad I need to replace the line also the block that it attaches to might have to be replaced. I have an owner's manual and a repair manual but I cannot find those particular parts. Where would I go to order those parts.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 1:54pm
I got one from AGCO a few yrs. back for a D17. Had all the correct bends. Seems it was around $100 bucks.
This page was generated in 0.230 seconds.
