6080 acting weird?
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Topic: 6080 acting weird?
    Posted: 20 Oct 2016 at 7:25am
Yesterday I was using my 6080 to bushhog soybeans that I had planted for a cover crop. I was running about 1500 rpm in second gear really taking my time. About an hour in to the job the tractor rpm increased to 2100 rpm. I throttled back and that did nothing. Turned the key off and again nothing. I downshiffted to first and that dropped the rpm a little. I was thinking of a way to stall it out when all of a sudden the rpms dropped to idle where I had the throttle set. Raised it back to 1500 and used it for another half an hour with no issues. This whole deal lasted around 30 seconds. Any one have any idea what may have caused this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2016 at 7:43am
Sounds like a sticky metering valve inside the injection pump. Bad fuel?? Might be time for a pump OHaul.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2016 at 8:13am
That was my guess, something pump related. I have been using on road diesel. What about some off road diesel for a little more sulfur and some Stanadyne?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2016 at 10:43am
Can't hurt.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2016 at 11:12am
on road, and off road fuel is same, just different color. Adding Stanadyne additive might help, but if the flex ring is breaking apart, it'll have to be serviced soon. A big piece may have got in the way of proper metering valve operation. I've seen this before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2016 at 1:59pm
Ok. I'll watch it. If it does it again I'll have to do something.
 I was thinking that I had maybe run into natural gas leaking out of the ground and I was suddenly rich!!!! That's if I didn't blow up.....
