LIFT ARM LATCHES
Message Reverse Sort Order
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Topic: LIFT ARM LATCHES
    Posted: 19 Oct 2016 at 11:05pm
getting off an on the tractor' all it was for is to get someone HURT' tripping on that junk time after time.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 1:02pm
I use the lift latches with bar in between them when using the AC SC #109 disc.  It helps with sway control and is easier on the arms when the disc is lifted.
Unfortunately, it can't be used when I hook up my SC #73 plow.  Then I have to use some individual lift latches on each arm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 12:04pm
I believe it started with the early D-17's and maybe even very late WD-45's. It added side-to-side strength between the lift arms with heavy mounted plows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 11:15am
I know an 1 1/4" bar fit them but DON'T use too lift a really,really heavy thing with the bar....it'll bend...sigh....
I'm thinking it was to keep the latches 'rigid' to each other ??
someone WILL know for sure !
One of my D-14s has it, the other don't....
Jay
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 11:10am
CAN ANYONE THE ME WHAT THE BAR WAS USED FOR THAT GOES BETWEEN THE LIFT ARM LATCHES?
THANKS, DAN
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
