Spin-out Cam Socket Wrench |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Topic: Spin-out Cam Socket WrenchPosted: 18 Oct 2016 at 10:31am |
My WD45 has the standard 1/2" square adjusters on the spin-out cams. I'm wondering what wrench or (preferably) socket is used to adjust them. I've been looking for some sockets designed for square bolt heads so I can get maximum "bite" on the cams, but I haven't found any thus far. I'd appreciate any suggestions for sources or alternative tools. [I've though about welding two 1/2" drive sockets together but am hoping for another idea!]
Thanks. Dave
WC, CA, D14, WD45
CTuckerNWIL
Posted: 18 Oct 2016 at 10:37am |
Take 2 old sockets and put them face to face with the square ends out. Weld together.
CTuckerNWIL
Posted: 18 Oct 2016 at 10:39am |
Most any place that sells good sockets will have 8 point sockets that will work. An impact socket would be best for this, having thicker sidewalls.
Dave(inMA)
Posted: 18 Oct 2016 at 10:47am |
Thanks! Appreciate both suggestions. :)
WC, CA, D14, WD45
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Posted: 18 Oct 2016 at 11:20am |
Square? Think all the eccentric cams I have are hex. I just use a 3/4 socket.
AaronSEIA |
Dave (Mid-MI)
Joined: 12 Sep 2009 Location: Hemlock, MI Points: 569 |
Posted: 18 Oct 2016 at 12:07pm |
WD45 should have 3/4" hex cam bolts. Sounds like you have CA parts on yours.
LeonR2013
Posted: 18 Oct 2016 at 12:16pm |
Yep.
Dave(inMA)
Posted: 18 Oct 2016 at 12:24pm |
Now that is interesting! I surely didn't know that. Are the correct ones still available?
Made a tool as suggested above - will paint it AC #1. :) Edited by Dave(inMA) - 18 Oct 2016 at 3:16pm |
WC, CA, D14, WD45
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54654 |
Posted: 18 Oct 2016 at 6:23pm |
I've still got the shop built one I made for the D10 and 12. Welded 2 impact grade extensions together, at the male ends...
AaronSEIA
Posted: 18 Oct 2016 at 7:18pm |
I've got a few sets of the correct ones, but they are all rusted solid. Need to free them up.
AaronSEIA |
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 18 Oct 2016 at 9:22pm |
The CA used the square head adjusters and the WD had hex head adjusters. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1795 |
Posted: 18 Oct 2016 at 9:43pm |
CA Had 3 lockers and one hanger. WD,WD-45 has 4 lockers.
Dave(inMA)
Posted: 19 Oct 2016 at 7:06am |
Tried my tool - I was able to tighten all the CA-style 'lockers' - 4 on each rim and also a 'stopper'. :) But the tractor is suffering from low self-esteem since it has the wrong locks!! I'll be watching for the proper ones.
WC, CA, D14, WD45
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 19 Oct 2016 at 7:24am |
What size tires/rims do you have on your WD45?
Dave(inMA)
Posted: 19 Oct 2016 at 12:15pm |
Hi Don. The tires are 13.6x28, marked as replacements for 12x28. The rims are (probably) 12x28, but I don't have a good way to measure the width except that the tire sidewalls seem to be in nearly the same plane as their beads.
WC, CA, D14, WD45
