D19D rebuild |
Michael Crowe
Joined: 11 Sep 2009 Location: Kansas City Points: 1726 |
Topic: D19D rebuildPosted: 13 Oct 2016 at 8:24pm |
Here is a video of my D19D after don Bradley rebuilt it. The pistons, piston pins, sleeves, rings, turbo and injector tips are new, the pump was rebuilt, crank turned, newer used fuel cells, a newer exhaust manifold and thermostat housing. I need to get a taller exhaust stack to save my ears! I also have a nos Hobbs hour meter that is turned on by an oil pressure switch so I can keep track of actual hours on the new mitor
I can't figure out how to get a hot link but if you copy the following address and paste it in a new window I t will take you to the video. http://www.youtube.com/watch?v=s0TNH4PFP_E&sns=em Edited by Michael Crowe - 13 Oct 2016 at 9:02pm |
Jerry H
Posted: 13 Oct 2016 at 8:37pm |
Glad to hear you got it done. Don sure does good work.
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 13 Oct 2016 at 9:27pm |
I hope she gives you years of trouble free service! This rebuild was a little tough to do with none of the newer D-19 pistons with the valve relieve out there to be found, so we did the next best thing, milled the set of older ser # NOS D-19 pistons he had in-stock to work with the newer head/camshaft, then decked the block and re-cut the counter bores.
I think it turned out fine. [TUBE]s0TNH4PFP_E&sns=em[/TUBE] |
WD45Diesel57
Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
Posted: 13 Oct 2016 at 10:01pm |
I could listen to that all day!!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
LeonR2013
Posted: 14 Oct 2016 at 4:08am |
Boy, that was some heavy duty grass and didn't miss a lick. Don does know his stuff on these Allis's.
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 14 Oct 2016 at 6:22am |
Impressive. I wouldn't want to have taken on that job when you can't buy the parts anymore it takes a real pro to make them out of something else. Very cool to hear it running. Definitely nice to hear a diesel that doesn't sound like the valves will explode like the old detroit we had in a truck here when I was a kid. Sounds great to me.
Michael Crowe
Posted: 14 Oct 2016 at 9:40pm |
I just got the hour meter installed; I plugged the meter in to account for the 4 hours I had on it before I got the meter in. It runs of oil pressure so it should very accurately track the number of hours on the rebuilt motor.
If you copy and paste the following you can see the video http://youtu.be/73guklgH0_U Edited by Michael Crowe - 14 Oct 2016 at 9:43pm |
Don(MO)
Posted: 15 Oct 2016 at 10:04am |
This how the inside looked as it was built, note the piston tops and you can see the mill work done to them.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8624 |
Posted: 15 Oct 2016 at 5:45pm |
Very nice! Don does a great job!
Thanks for posting! Your D19 tractor is awesome! Regards, Chris |
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 16 Oct 2016 at 7:06am |
If you don't have low hanging trees you work under, also turn your rain cap around, and that should knock the sound you hear down at least a bit. It looks like it is reflecting towards you.
Still in use:
shackratt
Joined: 06 Jan 2016 Location: Patriot Indiana Points: 70 |
Posted: 16 Oct 2016 at 12:09pm |
Awesome!!!
AC 180, TO-20, Case 580B Case 450 dozer
Michael Crowe
Posted: 16 Oct 2016 at 5:25pm |
I put a 3' pipe on it and did just that, turned the rain cap donut pushed the exhaust and sound forward; much better on my ears.
Gary(MO)
Posted: 16 Oct 2016 at 7:42pm |
Michael. I did find one thing wrong about tractor. It is western,Mo and not in eastern,Mo. Ha!Ha! Nice tractor Michael and great job Don.
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 16 Oct 2016 at 8:17pm |
I got to look your tractor over when I stopped by Don's last month but didn't get to hear it run. Sounds pretty darn good.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8755 |
Posted: 17 Oct 2016 at 7:33am |
Now that is awesome! !!!!!Darrel
bigredisb
Joined: 16 Aug 2016 Location: Racine WI Points: 185 |
Posted: 17 Oct 2016 at 8:35am |
That sounds soooooo good!
1961 Allis-Chalmers D15
1949 Farmall Super A |
