B Front Hub Cap
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: B Front Hub Cap
    Posted: 22 Jun 2010 at 11:13am
OK, so how to I remove the front wheel bearing cap?
Cars and trailers I am used to hammering the sides all the way around to work it off. This one doesn't want to budge, does it screw off?
Charlie
macec3(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macec3(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 12:13pm
I think they screw on and off. The hubcaps on my CA screw on/off.   You can use the hubcap to force grease into the bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 12:31pm
62 years of rust, should be fun!
Hope not to damage the cap. I think I will try one of those rubber strap domajiggers
Charlie
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 2:01pm
Or get a mighty big Crescent wrench!  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 2:04pm
That would be a bigun!
Charlie
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 5:28pm
You can use a monkey wrench to take off hubcap
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 6:11pm
If the monkey wrench doesn't work use a pipe wrench.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 6:54pm
I will bet money a "rubber strap domajigger" will not work, a nylon strap wrench might but I would have my doubts. Large Channel locks might work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 6:03am
I have a big monkey wrench, I was hoping to not bugger the end of the cap up
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 7:26am
Ok, the cap screwed off easy enough.
Removed the retaining nut and now I can't slide the hub off. What the heck is holding it on? I tapped it on the back with a sledge but it still doesn't move.
Charlie
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 11:11am
Charlie, after the nut is a washer, that should come off pretty easy.  Next is the outer bearing cone.  These get stuck pretty often.  tap all around it a few times and then try to take the hub off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 11:17am
I dug out all the grease and will try to tap the cone tonight. Thanks for the insight
Charlie
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 11:45am
You know, when I did that some 60 years ago and the tractors were relatively new we used a Ford Monkey Wrench.  You had to get a very good grip since the hub nut is rather slipery.  They were tough to do then.  I can just imagine how tough now.
However, the tools are so much better.  I thought I had died and gone to heaven when Vice Grips were invented.  We could clamp the three joint pieces the bagger whent on.
In any event
Good Luck!
Bill Long
This page was generated in 0.297 seconds.
