Fuel bleeding procedure
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Fuel bleeding procedure
    Posted: 30 Sep 2016 at 8:45am
Changed fuel filter on 7045. Can someone advise on the basic bleeding process? I've tried what I thought was sensible so far...Stanadyne pump if there is an option or differences
bigredisb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredisb Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 11:00am
I cant give you any specifics but here is what I do on all makes of diesels that I have had to bleed.
Open or remove the bleed screw or plug on the filter housing(s) and prime with the manual lever if equipped or open the housing and left them fill with gravity.
I then crack the injector line at the nozzle. I usually just pick the easiest ones to get to. Leave it open a bit and crank until you see fuel leaking then tighten. Normally I have to do 2 or three injectors to get them to pop off and run a bit.
BE CAREFUL, the fuel is under a lot of pressure and can injure you and shoot all kinds of places if opened up too much.
Edited by bigredisb - 30 Sep 2016 at 11:01am
1961 Allis-Chalmers D15
1949 Farmall Super A
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 8:50pm
On a 7045, remove the small plug on bottom of pump (takes a 3/8 wrench). Pump hand primer until all air is out, replace plug and pump primer up tight. Should start unless you have already pumped air in lines, if so pump primer, spin engine over a few times and pump primer again. May have to do it a few times before it starts.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 6:55am
Thanks for the replies guys.
And a big thanks to Ivan.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 7:27am
My only experience is with a Long but it should work with most any CAV pump. Crack the bleeder screw(s) on the pump and pump/crank until you get fuel out of them. This is where an electric pump is nice. Next I crack all 4 injectors and let the electric pump run until I start to get fuel in all 4. Then tighten the injectors and turn it over until it cranks. Might need a little help (ether) but it usually starts and runs good. I start mine at about 1/2 throttle. This way works for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 7:46am
Well, thanks. But this was on Friday, I've long since got it going. And actually, this procedure wouldn't quite cut it as it turns out.
flem1951 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2022 at 9:56am
I am having the same  problem. I cant get fuel out of the upper vent on the pump nor the top of the fuel filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2022 at 10:27am
You've got to be specific....what MODEL tractor ??
This page was generated in 0.152 seconds.
