D 17 transfer
littlejohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlejohn Quote  Post ReplyReply Direct Link To This Post Topic: D 17 transfer
    Posted: 27 Sep 2016 at 4:13pm
Can I take the engine out of a D 17 and stick into a WD.  The engine is the only thing that is good in the 17.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 10:06pm
Will need to use WD water pump and crank pulley.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlejohn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 10:17pm
Tongue  thanks
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 8:31am
To add to Mack's list, the water pump will need to be drilled out to 7/16" or install three 7/16" X 3/8" studs for mounting it, you need to find air governor housing (so you can put oil in the engine without needing to remove the hood to fill through the valve cover cap) cleaner, hose off a WD45 gas tractor, drill the crankshaft pulley out to fit the crank, re-plumb the oil filter lines to clear the steering shaft, might need to grind a little off the timing cover or frame rail on the right side to clear. Reuse the WD flywheel and clutch assy back in tractor. You might need to re-shim the front engine mount to angle cross mount.
