over-running pto clutch |
Page 12> |
| Author | ||||
LionelinKY
Joined: 12 Sep 2009 Location: Radcliff,KY Points: 698 |
Topic: over-running pto clutchPosted: 24 Sep 2016 at 11:03pm |
Somebody please explain to me the concept, purpose, and need for an over-running clutch for the pto especially as it pertains to working a rotary mower with a tractor like my WD45. We never used "bush hogs" on our farm but did all the other pto work associated with running a 100+ cow dairy farm. The WD45 did its share running haybines and harvesters, none of which ever damaged the pto drive no matter how many times the clutch was pushed in thereby stopping the pto dead. I have heard stories of people running their mowers and then busting the pto drives out of WD/WD45 tractors only to find out that it probably wouldn't have happened if they would have made sure to use an over-running clutch on the pto. Why do rotary mowers appear to be so much harder on pto drives than other pto equipment? I can understand a little oversight with a new product at first explaining why the oldest rotary mowers may not have a built in over-running clutch. Do ALL new mowers have over-running clutches on the pto now or only certain brands? I have a friend offering to buy a "bush hog" if I would be willing to use my WD45 to help him keep a small field mowed down. I would like to make sure that everything is set up correctly so as not to damage my tractor whether that means getting a particular mower or having an over-running clutch installed on my tractor pto. Any and all information will be greatly appreciated. TIA
| Sponsored Links | ||||
VAfarmboy
Posted: 24 Sep 2016 at 11:39pm |
Because if you don't have one and push the clutch in on a tractor without a "live" PTO the still spinning blades on the bush hog can drive the transmission through the PTO shaft (creating an unsafe situation), or bust the shaft. Same deal with the spinning flywheel on a baler. The overrunning clutch lets the pto driven implement freewheel rather than turning shaft and continuing to drive the tractor forward or breaking the shaft when you push the clutch in.
The overrunning clutch snaps onto the tractor's PTO shaft not the mower. I am not aware of any mowers that have built in overrunning clutches. They all have slip clutches to protect the drive-line on the mower. Most tractors built since 1960 have a "live" PTO that is independent from the transmission so this is not an issue but on the older ones you need an overrunning clutch for some applications. Does your WD45 have a three point adapter or an aftermarket three point hitch on it? If not you will have to have a snap coupler hitch fabricated for the bush hog, unless you get a trailer type bush hog with a lift cylinder. Edited by VAfarmboy - 24 Sep 2016 at 11:52pm |
LionelinKY
Posted: 25 Sep 2016 at 12:19am |
Lots of WD45s also ran balers, blowers, and choppers all which have a rotating mass that doesn't like to stop abruptly. I don't recall ever hearing about pto issues unless it involves a bush hog. The slip clutch doesn't allow for the necessary freewheeling of the rotating mass after the tractor pto has been stopped?
Herb(GA)
Joined: 15 Sep 2009 Location: United States Points: 1039 |
Posted: 25 Sep 2016 at 2:31am |
The momentum of a large implement pushing the tractor forward is normally not a problem with balers or cutters because this usually occurs in the middle of a field. Bushhogs are often used in corners of fields or among trees and along fences, where one can readily get into a tight spot. I have broken off a couple wooden fence posts with tractor front axle/front wheel because of this inertia. This situation can be prevented by quickly placing the gear shift into neutral (not easy to do if there is a load on the geartrain).Herb(GA)
Jack(Ky)
Posted: 25 Sep 2016 at 3:18am |
As long as you use the hand clutch you don't need one of these. A WD has "live pto" as long as you use the hand clutch to stop forward motion and leave the foot clutch alone.JP
'59 D14 '68 170 Diesel '81 7020 40 All Crop
tractorboy
Joined: 03 Oct 2009 Location: southern Va Points: 478 |
Posted: 25 Sep 2016 at 4:10am |
jack is right. you wont have a problem, hand clutch works great for that. once youre used to it, it'll be natural, especially with your farm experience !!
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3123 |
Posted: 25 Sep 2016 at 4:35am |
I can't see how a brush hog driving a WD/WD45 forward a little is going to damage anything on it as it takes very little force to drive the tractor forward.I've run those tractors all my life and never had an over riding clutch on one
and have never known anything to get damaged because of it. |
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54698 |
Posted: 25 Sep 2016 at 5:33am |
Another thing to consider is balers have a built in ORC in the drive line, at least NH ones...
As others have said, use the hand clutch. the only time to step on the foot clutch, is out in the open, when changing gears. If you use the hand clutch, to stop, then step on the foot clutch, you then have to wait for the BH to spool down, before shifting. If you just step on the foot clutch, you let the BH drive the tractor forward, and use up the stored energy, making for a quicker shift...
Burgie
Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Posted: 25 Sep 2016 at 5:50am |
With the ORC you don`t have to wait for the implement to spool down before shifting gears.
"Burgie"
kev/ont
Joined: 12 Sep 2009 Location: Castleton Ont Points: 282 |
Posted: 25 Sep 2016 at 6:48am |
It'll never hurt the tractor 1 bit. It it down right dangerous for the operator of the tractor in certain situations. The brakes will not stop the tractor and the inertia of a rotory mower. So on hill sides or tight corners you would run over or into obstacles before you ever knew what happened. However with a wd/wd45 use the hand clutch, no issue. Edited by kev/ont - 25 Sep 2016 at 6:50am |
LionelinKY
Posted: 25 Sep 2016 at 6:58am |
My main concern is being able to safely stop the pto when I want to such as when the job is done or when I may feel the need to (emergency) without breaking any shafts or shelling any gears in my WD45. So, it sounds to me like the consensus is to disengage the hand clutch first and then I would be able to use the foot clutch to stop the pto and disengage the pto drive safely without any fear of damaging something?? I have to admit, the ORC does sound more and more like extra insurance against OH $h!+ moments that we all know can happen when we are out there trying to get it done. Thanks guys. Learned something new today on top of why Dad insisted that us boys use the newer tractors when we started doing pto work in the fields. He used the WD45 on occasion but we only got to use the Oliver 1750 or 770s and sometimes even the 190XT. The only pto job we ever did with the WD45 was its main summer job of running the manure spreader after the daily barn cleaning. Usually never unhooked from the spreader except rare occasions when Dad needed it to run the haybine.
Gary Burnett
Posted: 25 Sep 2016 at 6:59am |
I've stopped my 10ft Sidewinder cutter with the brakes on my D19 when I pushed in the
foot clutch.Actually its an advantage because then the cutter can be stopped quickly if it hits something or better before it hits something.I think some posters are working off theory on this one not actually experience.Or maybe they had an 8N Ford(LOL) |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Posted: 25 Sep 2016 at 7:26am |
You can also quickly drop the engine rpm and slide the pto out of gear. The blades will freewheel till they stop. Don't forget, if a WD/WD45 has a weak spot it is the PTO gearbox. Panic stops using the brakes to nearly instantly shut down a very high inertia mower can (only can, not will) grenade the gearbox. Simple fix is to buy an Allis spin mower. They came with an orc in the driveline.
Oh, and a slip clutch is NOT the same as an over running clutch. They are spring loaded devices designed to hold power under normal loads but will "slip" if a quick shock (like a stump or scalping the ground) occurs. AaronSEIA |
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Posted: 25 Sep 2016 at 7:43am |
This is a great topic, I was going to ask a similar question, as I bush hog in tight spots quite a bit. I would actually like to install a slip clutch and an overrunning clutch on my bush hog. I'm not sure if a guy has to modify the driveshaft to use both, or lengthen the drawbar? Because won't you be adding several inches to the driveline by using both?
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 25 Sep 2016 at 7:53am |
All things being equal brakes on a D19 are far better than those on a WD, WD45 or even the D17. I have been in a situation, so I am not posting theory. Yes you can stop a 5' rotary mower with WD brakes, even in moderate shape, but it still takes a foot or two, if you are standing on them. I imagine the same is true of the 10' on the D19. Bottom line that foot or two of ground travel in some cases can mean the difference between life or limb, on Nothing!!!!! Now factor in most WDs have poor or weak brakes for whatever reason, and now the 6' brush cutter is pushing you 5-10' when you really want to stop now.......... BTW...The Allis pull type mowers I have seen all have overrunning and slip clutches built in. They sit right in front of the gear box.
Edited by Orange Blood - 25 Sep 2016 at 7:53am |
Still in use:
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7570 |
Posted: 25 Sep 2016 at 8:08am |
A slip clutch is usually built into the bush hog (but I do not know of many that have them) - it is not something that can be put on it. The over-running clutch on the other hand simply goes on the tractor's PTO and then the bush hog's PTO attaches to it. No need to extend the drawbar or shorten the PTO shaft for it to go on either. To all the nay sayers, I have to say that the over -running clutch has been one of the best investments I have ever made for using the rotary mower. |
Gary Burnett
Posted: 25 Sep 2016 at 8:43am |
If you need to stop the tractor immediately then thats what the had clutch is for. |
CTuckerNWIL
Posted: 25 Sep 2016 at 8:45am |
A slip clutch CAN be added to just about any PTO equipment. http://www.ebay.com/itm/Add-on-Rotary-Cutter-Slip-Clutch-Easily-Add-a-Slip-Clutch-to-Your-Shear-Bolt-PTO-/371504621928 You can buy them off the internet. I also KNOW of situations where adding an ORC has caused real problems if the PTO shaft isn't altered. ANSI drawbar length is critical here. You CAN very easily bottom out the sliding PTO shaft when going thru a dip. The tractor facing uphill and a pull type mower still going downhill can ruin your day if you just added an ORC and didn't check things out first. ![]() Now,if you add the ORC and lengthen the drawbar to 14 inches from the end of the ORC to the center of the pull hole, you should be OK. Edited by CTuckerNWIL - 25 Sep 2016 at 8:51am |
Orange Blood
Posted: 25 Sep 2016 at 9:01am |
I disagree respectfully......Almost ALL tractors out there have a foot engine clutch, very few have a hand clutch, even among Allis tractors. Instinct kicks in during emergencies, and the foot clutch is what you "grab" for, not the hand clutch unless that is all you run. So using the hand clutch is not "natural instinct" to those who don't use the WD much anymore.
Edited by Orange Blood - 25 Sep 2016 at 9:03am |
Still in use:
Gary Burnett
Posted: 25 Sep 2016 at 9:11am |
It is for me I reach for the 'hand clutch' sometimes on my Olivers(LOL),I have multiple brands of tractors I use so I have to keep in my mind what I'm driving. |
ocharry
Posted: 25 Sep 2016 at 11:02am |
hi guys
i just got a new to me ac 170 this spring,,,i went from a jd to this tractor and it was a learning curve but i'm getting there.... after i got this ac home i thought well with the extra ponies i can get a bigger mower,,,so i got a new 6' bush hog razor back....nice mower the difference between the two tractors is the jd had live power....foot clutch made no difference to pto drive,,,it had its own clutch set up after a little seat time and a push or two,,,,i thought all tractor had the live pto,,,,i got to doing some research and find out that the foot clutch does disengage the pto on the ac,,,,that was an ahh-haaa moment,,,, so i got a over run clutch and a slip clutch and put them on,,,,,now this mower came with a shear pin set up,,,and i used that plus the slip clutch for the drive line at the gear box on the mower,,,,and the over run clutch at the pto shaft on the tractor,,,,over kill,,,,maybe,,,maybe not,,,,but i feel better about it and it works just fine oh and i had to cut 12" off the drive shaft,,,,,i still have 4" of dead space when it is all the way at the top of the lift,,,,,,,MAKE SURE YOU CHECK THAT,,,,if it bottoms out you WILL break something sooner or later,,,,,maybe the first time my .02 ocharry
Gerald J.
Posted: 25 Sep 2016 at 11:29am |
If the PTO is driven off the transmission like the 8N, the bush hog spinning inertia will make you hit buildings, poles, trees, and fences when you try to get close to them. Sounds like the two clutches of the WD can solve that if the operator realizes the hand clutch is the only way to stop the forward or reverse motion of the tractor, but these days most of us are used to the foot clutch doing that work. Hitting those obstacles can do damage to the machinery or those obstacles costing way more to repair than the cost of an over running clutch.
Gerald J. |
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 25 Sep 2016 at 11:46am |
Yes always check the free play in any pto setup when you hook up the first time. I remember there was a broken pto shaft for one of the tractors here when I was a kid. The shaft broke on the first turn because no one checked it on something we just bought. It was the tractor side that broke too pretty expensive and a pain to replace.
TimNearFortWorth
Posted: 25 Sep 2016 at 12:37pm |
Said it before on here but it warrants repeating; a good number of folks are killed each year because of tractor "push" when using a brush cutter, mainly when they are pushed into a limb (head trauma).
Doing fence lines myself currently before winter seeding and always 1st low range so I hopefully have a bit more response time if ever required. It only takes a second to get into very deep trouble with a brush cutter of any size . . . . |
TREVMAN
Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
Posted: 25 Sep 2016 at 12:42pm |
Install an orc. It helps prevent shock loads to tractor driveline and engine. You'll be glad you did. "Bush Hogging" is very hard on tractors...JMHO, Trev.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 25 Sep 2016 at 1:09pm |
I have an ORC on my 8N, and I really like it. Like was said earlier, you don't have to wait for the implement to wind down when shifting. Of course, I had to have an adapter of some sort because the 8N, as well as my B, have a 1 1/8" PTO shaft. So the ORC input is 1 1/8" and the output is 1 3/8". This way I can switch it easily between the 8N and the B, depending on which is doing PTO work.
A little off topic...I've never seen any PTO implements that require 1 1/8" shaft. Surely they made some though? All I've seen is the drive sheave for my sickle mower, which fits the 1 1/8" shaft.
Gary Burnett
Posted: 25 Sep 2016 at 1:43pm |
So you got an 8N huh? Maybe you can settle a question for me fellow with an 8N swore it could out pull my 3 legged Mule so I was gonna to bet him but he backed down when $$$ became involved.What'd you think? |
CrestonM
Posted: 25 Sep 2016 at 2:20pm |
8N at 1/2 throttle could out-pull a 3 legged mule! Lol
How often do you see one mule pulling a 2 bottom plow?
Dan73
Posted: 25 Sep 2016 at 2:21pm |
About as often as I see a 8n pulling one... but then I never seen anyone actually use a 8n
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Posted: 25 Sep 2016 at 2:29pm |
ORC is especially handy when using a Bush hog or mower backing up to building, fence, creek bank, or other drop off. Push in foot clutch and stand on foot brake. Brakes don't seem to work as well in reverse.
Page 12> |
