190xt starter solenoid clicking
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Topic: 190xt starter solenoid clicking
    Posted: 24 Sep 2016 at 12:58pm
Hi All-
Got distracted the other day when I shut off the fuel to the 190 and left the key turned on overnight, which wore down the batteries. So, long story short, the batteries are recharged to over 12V, but now there is only clicking at the starter solenoid.  Any suggestions would be helpful.  New starter solenoid in order?
Thanks.....
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 1:32pm
Sounds like the batteries are still low.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 1:34pm
Check the battery voltage while cranking the engine. A cell may have shorted in the battery. Cranking batteries aren't very tolerant to being run way down. Deep cycle batteries are more forgiving.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 2:04pm
X2
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 7:44am
check connections also.
This page was generated in 0.152 seconds.
