Allis C
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Topic: Allis C
    Posted: 31 Aug 2016 at 6:29pm
This is the one I recently bought from Mn.
Tractor was built into high crop with 36" rear wheels.
Tires will need replaced but for know they will work.
Parts replaced were the water pump.
lower radiator pipe had to cut off about 3/8" to get to fit may have been the Radiator that caused the issue.
Also the radiator was bad, so I had new one the shelf for about 10 years decided to use it.
Change out the spark plug wires and shifter boot and knob.
Clean the points and put I new resister on the mag.
Clean the gas tank out some had normal tar and rust in it.
Still will need some work but good enough.
Also decided to make the manifold work with the new type of mufflers.
Had to cut off the muffler and also tap out the hole and install helicoil.
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 7:34pm
Love it!  Nice tractor.  Thanks for the pics.
Steve
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 8:52pm
   Good job Mr Richard.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
This page was generated in 0.184 seconds.
