Unstyled WC
Ed-In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed-In Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled WC
    Posted: 11 Feb 2010 at 6:49pm
I was wondering if anyone out there has a unstyled WC with starter that they might be interested in getting rid of. Looking for one that runs, but needs work, somewhere around Indiana. All depends on condition and price. Just looking for one to tinker with. Thank you.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 7:43pm
Someone will correct me if I'm wrong but I don't think unstyled came with starters. Not that some weren't converted after the fact.
Waukesha B, B, IB, G, styled WF, D17, 615 backhoe, 2-Oliver OC3's, 5 Ford Model T's, 3 Model A Fords, 34 Ford coupe, 57 T-Bird
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 8:55pm
I may be wrong but I was thinking that the last one"s sold in 38 had starter's on them ???
Randy(Mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 9:03pm
I have an unstyled with a starter for sale, ran a couple of years ago, needs tires, $350 The only problem I am in Mo, email if interested
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 9:04pm
I have several bell housings off styled that you can put on any unstyled to give you starter. This  was done now and then have seen several and have one on the spare parts tractors now. If interesed call 507-482-6940
Phil
Andrew Kimbrough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Kimbrough Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 9:13pm
This is a common debate, some believe that the last unstyled wcs had the option of coming from the factory with electric start.  I have heard many that also say that is not true and that there is no proof for it..   Anyways..  there are a lot out there with electric start because people converted them (or some say a small number came from the factory that way)   either way you should be able to find one..  I had a parts machine that I had for sale that had all of the electric start parts there but a stuck engine, but most of it is gone now.
DGKWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DGKWC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 9:47am
Hi can you send me some info on the tractor or call me 810-599-0790.  Thanks David
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 10:00am
I have a 39 WC, it is a styled model, but it has a good unstyled radiator.  It has the distributor conversion, I tuned it up and it runs good, the electrical system works, has a new water pump, new battery box.  The minuses, it needs both front wheels and tires, and one back tire, and needs the fuel system cleaned out now.  $650 as it sits.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 11:24am
I agree the last WCs in 1938 did have starters, lights, & generators, but these were also the first styled WCs!! I'm not convinced that there were ever any factory produced unstyled WCs with electrical enhancements. However I think the converted ones are practical & kind of neat. Kip
Edited by Kip-Utah - 12 Feb 2010 at 11:25am
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 4:47pm
Ok heres a spin I saw a pic in another post and it is a unstyled WF that has a starter but the housing isn't off of a styled wc or wd as it looks like their is no place to mount the gas tank saddle
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2010 at 10:41am
Denis, The unstyled WF's were made into 1940, so there could be some out there that came with electric start that are a little different than the 38's and earlier ones.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2010 at 11:27pm
Charlie- My WC-  I noted that it didn't show any evidence of being an 'after-the-fact' conversion, but your note brings one thing to light... My WC... could have been a WF... it had a cobbled-up wide front (made from a truck axle) when I got it.  I just assumed it was an NF...  I'll hafta go back and re-check the serial number, and see if the rearend has been changed... it may have originally been a WF...
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 8:12am
Gentlemen,  The first starter WC's that I recall was in 1938.  I recall at our family hanksgiving Dinner we left early so that we could unload our first carload of STYLED WC"S with starters.  Also, the starter did not have the heavy wire starter rod.  We got them from parts later and added them.
However, we did not care since all Pop had to do was push the starter button.
I cannot comment on WF tractors since I never sold one new but I do know that starters came only on styled 1938 WC's.
Any Flat Top WC with a starter on would have to be a conversion of the clutch housing with a newer WC.
Good Luck!
Bill Long
babs8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote babs8070 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 10:34am
Styled wc,s came out late in 38 but some unstyled wc,s were still assembled in 39 according to the allis chalmers book. I would think some of the unstyled ones would have a starter on them from the factory when they were doing the crossover but I could be wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 3:15pm
What book Babs? Norms Farm Equipment book does not mention it. The unstyled tractors that were built after 1938 were WF's and I'm sure there were unstyled WC's still  on lots across the country after 38.
Edited by CTuckerNWIL - 16 Jun 2010 at 3:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote babs8070 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 7:50pm
the allis chalmers story by c h wendel
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 7:57pm
  can put a starter on any unstyled unit have done it before  it is still in the family an mom is still living  also have my name on it if available   will help you
  1-574 -342-4545
