WD Plow hook up
PatrickBeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatrickBeth Quote  Post ReplyReply Direct Link To This Post Topic: WD Plow hook up
    Posted: 10 Aug 2016 at 12:49pm
Friday going to see a two bottom plow for my WD. Does all snap couple plows work on a WD? I know the CA s used them too... Anything I should be looking out for so I don't buy a plow that is too small? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 1:03pm
I've hooked up to the snap-coupler eye on the plow with the regular drawbar clevis and a bolt. You do not need the snap-coupler bell on the tractor. It isn't easy, but it can be done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 1:09pm
Dr., in my eye, I see his WD as converted to SC already? I think his question is about length of the plow drawbar and width of the lift links.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatrickBeth Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 1:14pm
Converted to snap coupler... need to know if any plow will work, just in case a CA snap coupler plow is too small. All I know about this two bottom plow has a snap hitch, but whether or not it will work on a WD if it was meant for a CA...
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 3:03pm
Beam for a five tooth ripper was to short for a D/14.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 6:47pm
Measure the width of the lift links. If it's the same as your WD it'll work if it's about 6" narrower it's for a CA. The plows with two sets of hole on the lift bar can be used on either. The length should be the same. I've mover the Three point adapter from a CA to a Wd45 length wise they were the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatrickBeth Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 7:02pm
Thanks Dakoda, that will give me what I'm looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 5:49am
 A CA plow will have a shorter drawbar that what would be usable on a WD. The lift links are not stationary so they won't be a problem.  A WD/WD45 drawbar could be put into a CA52 plow or you could find a "long" eye to bolt to the CA drawbar on the plow.
