D17 Series 2 Muffler? |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Topic: D17 Series 2 Muffler?Posted: 25 Jul 2016 at 6:59pm |
What should a D17 series 2 have for a muffler? I've seen the skirted style like a WD, and a round clamp style like the cheap farm store replacements. I really need a new one but am not sure which one is correct. By the parts book with a serial number of 33xxx it should be a 70234494. I don't see a diagram for how that muffler attaches to the manifold/tractor.
AaronSEIA |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7569 |
Posted: 25 Jul 2016 at 7:07pm |
The series II uses the cylindrical muffler with a skirt at the bottom with 2 holes in it. AGCO carries them - they are the real Nelson muffler too (for a price).
AaronSEIA
Posted: 25 Jul 2016 at 7:19pm |
That would be the same as the series 1, but the parts book shows a split at 32,000 and a different muffler but no picture of it.
AaronSEIA |
Posted: 25 Jul 2016 at 7:37pm |
Series 2 gas mufflers are round yes, but are LARGER in diameter and have a larger hole in the hood. The mounting method is different too, as I think they had gone to the threaded pipe in the manifold with the larger muffler using a muffler clamp. They were trying to reduce the noise levels of the original Nelson muffler with this change.
DSeries4
Posted: 25 Jul 2016 at 7:38pm |
I think the only different muffler was the oval mufflers that they switched to for the Series III and IV models.
DSeries4
Posted: 25 Jul 2016 at 7:42pm |
Oops, I stand corrected. Dr. Allis would be correct.
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2338 |
Posted: 25 Jul 2016 at 7:50pm |
I hate to hijack your post Aaron but I have a very similar question. What would be the correct muffler for a Series IV gas?? Thanks guys, Ryan
AaronSEIA
Posted: 25 Jul 2016 at 7:52pm |
Hmm. Not sure my manifold has threads on the inside. What size pipe did they use and what threads would it be?
AaronSEIA |
AaronSEIA
Posted: 25 Jul 2016 at 7:54pm |
Series 4 would be the oval one. I think the inlet and outlet were offset.
AaronSEIA |
Posted: 25 Jul 2016 at 8:04pm |
Series 3 and 4 are oval mufflers, again for a quieter running tractor.
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 999 |
Posted: 25 Jul 2016 at 9:25pm |
If you find a source for the right one let me know. I'm looking for a good one for my series 2 D-17.
Posted: 25 Jul 2016 at 9:59pm |
Correct series 2 gas muffler is 4 inches to 4 1/2 inches in diameter. Old Nelsons were about 3 inches diameter.
Joe(OH)
Posted: 25 Jul 2016 at 10:52pm |
79fordblake
Joined: 01 Jul 2010 Location: West Kentucky Points: 829 |
Posted: 26 Jul 2016 at 3:23pm |
Just got this for my WD45 engine im building.
Posted: 26 Jul 2016 at 3:46pm |
That would be for all WD-45 and early generation D-17's.
Brian Ahart
Posted: 26 Jul 2016 at 4:13pm |
The larger diameter straight-through muffler for the D17 Series II (70234494) is still available through Nelson. The Nelson part number is 06923T. Check out seller "nelsonglobalproducts" on eBay. I bought one a few months ago just to have one in stock.
http://www.ebay.com/itm/70234494-AGCO-VERTICAL-TRACTOR-Muffler-06923T-by-Nelson-Global-Products-/272256504861? |
A-C Weight ID reference and other goodies at brianahart.net
ac45dave
Posted: 27 Jul 2016 at 8:54am |
this gives a good clear side by side dimension comparison between series 1 and series 2. http://www.stanleymuffler.com/catalog/Fall2011.aspx#/6/
AaronSEIA
Posted: 27 Jul 2016 at 10:56am |
Brian, does that current Nelson muffler have the same Nelson sound everyone is after? I see OK Tractors sells the correct series 2 muffler (or at least dimensionally accurate) and also has some kind of pipe adapter. Looks like it just slides into the manifold as opposed the threading in.
Brian Ahart
Posted: 27 Jul 2016 at 10:23pm |
Aaron, I have not installed the muffler, so I cannot testify as to the sound. It does have the perforated interior as with other Nelson units. The input is slotted, with an ID of approximately 1.9 inches and a body diameter of just under 4.5 inches. |
DSeries4
Posted: 28 Jul 2016 at 9:36pm |
If it is a Nelson muffler, it would still have that Nelson sound. They were OEM for these tractors. |
