Fluid from tires
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Fluid from tires
    Posted: 14 Jul 2016 at 6:24am
What do you do with unwanted fluid in tractor tires?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 6:32am
pends on what it is.
Ain't discussing where the cacl went.  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 6:33am
Spray it out on the gravel in your driveway , or if you live on a gravel road, spay it out front of the house. It keeps the dust down and stops weeds from growing.
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 7:23am
  Howdy Lon,
When I took my fluid out of all my tires, a local repair shop took it all. Even give me barrels to put it in. Most likely selling it again or use it again.
Kurzy
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 7:42am
Originally posted by Kurzy Kurzy wrote:
  Howdy Lon,
Kurzy
That's what I had done when I had a JD A years back.
Wink
I am a Russian Bot
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 8:01am
I need like 4 55 gal drums :(
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 8:08am
rock quarry sprayed their drive with it,don't you have some fencerows that need some attention?
Edited by SteveM C/IL - 14 Jul 2016 at 8:09am
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 8:09am
CACL makes great weed and brush killer. 4 drums full will do lots of fence line.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 9:22am
I pumped all the calcium chloride from my 200 into ground hog holes in barn.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 9:50am
Most local farm tire shops will recycle it. call them I used to go pump it out of guys tires and not charge for doing it. Would give most of it back to guys who had a blow out or otherwise ruined a tire. Made good customer relations on both ends.
firecowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 1:40pm
brush killer
allis g 7045 200 wd45 wd45d c ca 6080 u
orangeman69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman69 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 9:59pm
our tire man comes and pumps it out for no charge and probably resells it.
d17,d17nfpuller,d-17IVdiesel,d19gas,d19diesel nf,d21seriesII,180,190xtseries III,200,210,7020,7060,7080w/8.3cummins,8070fwa w/8.3cummins,8550 185 w/322 original hrs.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2016 at 7:29am
Dust control is one of the manufactures intended uses.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2016 at 8:33am
  Howdy Lon,
Kurzy
Our local tire guy comes and does this for us
