Agco paint/ hardener question |
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
Topic: Agco paint/ hardener questionPosted: 06 Jul 2016 at 5:56pm |
I am getting ready to paint a 7030 and am using Agco paint. I'm wanting to buy the hardener for it, but is it an alkyd enamel or acrylic? I can't remember what I used last time I went through this and I can find any posts on it. What kind of hardener and thinner does everyone use with it? I'm thinking I used Valspar Renew hardener and either laquer thinner or naphtha thinner, but wasn't sure.
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2338 |
Posted: 06 Jul 2016 at 8:19pm |
I am about 90% sure Agcos paint is enamel. Hopefully someone else will chime in! Ryan
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7569 |
Posted: 06 Jul 2016 at 8:58pm |
AGCO paint is indeed enamel.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 06 Jul 2016 at 9:37pm |
This will really show my stupidity, but I thought all paint was enamel? Can someone explain in simple-man's terms?
Thanks!
7060
Posted: 06 Jul 2016 at 9:40pm |
After searching google for over an hour I finally typed the right thing in and I don't even remember what it was, but found a link to all of Agco's paint tech sheets, plus the part numbers for all of the paint colors. Here it is incase someone else needs to know.
http://www.rudolphbrosinc.com/partsguides/agcopartspaintguide.pdf Also I won't know until I actually spray it and compare, but DuPont RS562 looks to be almost an exact match to Agco's maroon paint in the rattle cans. Edited by 7060 - 06 Jul 2016 at 9:51pm |
BenGiBoy
Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
Posted: 07 Jul 2016 at 7:36am |
'39 Model B
Tractors are cheaper than girls, remember that! |
Play Farmer
Posted: 07 Jul 2016 at 8:01am |
When I was looking for the maroon codes this is what I found. I never did end up having it mixed up so take it for what it's worth;
wildcat2
Joined: 03 Aug 2011 Location: United States Points: 110 |
Posted: 07 Jul 2016 at 8:12am |
Last time I bought some Agco paint I also got some hardener with it. It is Valspar renew low voc hardener, number REN4001. The can says 8 parts paint 1 part hardener. Just painted some wheel weights and it worked every well. I also used the appropriate reducer.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2584 |
Posted: 07 Jul 2016 at 10:53am |
I'M CURRENTLY USING AGCO PAINT AND THINNING WITH ACETONE AND USING VALSPAR HARDENER AND ITS LOOKING PRETTY GOOD.
DAN
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Joined: 11 Sep 2009 Location: illinois Points: 89142 |
Posted: 07 Jul 2016 at 1:19pm |
enamel reducer or acetone will work as a thinner. I would NOT use laqueer thinner. That is for laqueer paints or cleanup.
DougG
Posted: 07 Jul 2016 at 1:57pm |
What combination is bad for your lungs?
ac45dave
Posted: 07 Jul 2016 at 2:06pm |
Stan IL&TN
Posted: 07 Jul 2016 at 2:51pm |
I believe anything with harder or activator in it is bad news and should only use it with a fresh air source or if you like to take a chance you can use it outside and stay upwind of the overspray. |
1957 WD45 dad's first AC
Toscani NE SD
Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
Posted: 07 Jul 2016 at 7:10pm |
I will answer the question, its alkyd. not acrylic.
Play Farmer
Posted: 07 Jul 2016 at 8:54pm |
All of them, some worse than others. If you're painting just wear a mask, your family will thank you. |
