hesston 5500
nathan4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nathan4 Quote  Post ReplyReply Direct Link To This Post Topic: hesston 5500
    Posted: 02 Jul 2016 at 8:58am
im new here but been reading and learning for awhile now. i do own a wd45 and a 180 gas . i just bought hesston 5500 baler and according to manual it sounds like i have to turn pto off in order to unload a bale . do i have to or can i leave it on?
Morgan in AR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morgan in AR Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 9:07am
Dad had a 5800. You have to shut off the PTO to open it. With your 180, just mash the clutch. Works pretty well. Dad baled with a 170.
If we loose freedom here there is no place left to escape to. This is the last stand on earth. -Ronald Reagan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morgan in AR Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 9:24am
Also... good luck starting a bale. That's the hard part.
zulawski87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zulawski87 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 11:06am
100 series works nice for round baling. Put pd in neutral to tie. Push clutch in to dump the bale. Love baling with our 185 or 200.
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 9:15pm
I have 2 5500 balers.  Yes you have to stop the pto to eject the bale.  Also to the comment about starting a bale,  If the belts are good and the hay is dry, the bale will start good.  I like the baler, simple to work on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nathan4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 10:14pm
to those who responded THANK YOU. i went out and baled this afternoon and no major issues,just old belts breaking.no problems starting a bale.lot easier than square baling!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2016 at 5:36am
some of the Hesstons had what they call a short grass starting bar, which was a piece of angle iron, with a plate over the angle, making it triangular in cross sectional shape.  when it's removed, the bales start much easier...WinkWink
This page was generated in 0.285 seconds.
