D-19 Weight
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: D-19 Weight
    Posted: 09 Jun 2010 at 3:34pm
I'm looking at a D-19 and need an approximate weight so I determine if I can haul it or not. I know Norm's book lists the tractor at between 6600 and 11,040 some odd pounds when fully balasted. This tractor is a gas with fluid only in the rear tires, no weights but an after market three-point and comes with a rear-mount blade. Any chance it may come in under 9,000 lbs?
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 3:52pm
I'm not an expert but my guess would be under 8000 lbs..
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 4:07pm
9000#plus without the blade.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 11:36pm
I'd think it would be under 9000, does it have 18.4 x 34 or 15.5 x 38 on the rear?
ALLIS EXPRESS!
This year:
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 12:33am
easily under 9000. narrow front 19 diesel with 18.4 34 tires no fluid and 210 lb driver we weigh in at 5990.  Still has all lift arms and factory hitch nothing stripped off.
Dutchboy Johan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 3:42am
Our D19 is a 1962 gas with 16.9 34 tires on it, no fluid or other weight. It weight 2840kilograms. Not sure what it would be in LB.
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands
Allis-Chalmers 190XT Ser.III #26829XTD
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 7:04am
Johan, that would be something like 6248 pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 8:14am
The tractor has 16.9 X 34s and a wide front end.
