ca engine freeze plugs
AChoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AChoe Quote  Post ReplyReply Direct Link To This Post Topic: ca engine freeze plugs
    Posted: 16 Jun 2016 at 7:34am
I have a model CA that I have restored and the large freeze plugs on the right side of the engine (3) are leaking oil. I have looked for replacements but cant seem to find any this size. Does anyone know where to get these or is there a way to remove them from outside the engine without damaging them. I know I can seal them up if I could get them out without damaging them.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 10:21am
The freeze plugs would be leaking coolant, not oil. New ones are available from suppliers on this site like Tony's Tractors.  They are removed by punching or drilling a hole in them and then removing them from the outside. They can't be removed without damaging them.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 10:55am
No freeze plugs in the block that could leak coolant!  They are core plugs that cover the galley that the  oil from the oil filter travels  over the camshaft lifters to the front of the engine and back into the oil pan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 11:01am
I have always been able to get them from NAPA. The way to get them out is to hit them in the center with a ballpeen hammer to force/bend the center in. Nothing behind them to get damaged to bend them in enough to release the outside pressure.
Here is a picture from my Tie bolt story on how to draw top block cracks tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AChoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 11:08am
Thanks for the help. And you are correct there is no antifreeze at that location. these are just open into the pushrod galley and have no pressure on them, they just seep enough oil to make a nice shiny paint job look terrible after a few hours of mowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AChoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 11:14am
I also have an issue with an oil leak on the hydraulic valve body. Directly below the raise/lower valve is the main valve body. the top of the main valve body has four threaded caps/plugs that retain internal components or passages. when these were line bored at the factory it looks like they bored all the way through the bottom of the valve body and then plugged the holes in the bottom. one of these , I believe plugs, is leaking enough to make an oil spot on my clean shop floor. I would like to repair it but I'm not sure how to attack it without damaging the body or the plug, which might be hard to find a replacement. has anyone had any dealings with these?
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 11:34am
Achoe you can take a large ball peen and gently hit the freeze plug around the center until it loosens up and then pop it out. Then take the plug and using the hammer again tap it back to the original shape. Clean it and the block up, add just a touch of sealer if you want and put it back in. Hit it with the flat face of the hammer this time one time. It might take a second lick, but don't overdo it. I've done this many times in a pinch and it's always worked. Poor people, poor ways you know. Leon R   Cmo
Post Options Post Options   Thanks (0) Thanks(0)   Quote AChoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 11:41am
thanks Leon that's what I will try first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 6:08pm
Or, you could drill a small hole, off center, and thread the screw, of a slide hammer dent puller, into the hole, and whack them out, that way...
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2016 at 9:34am
I have ordered them from McMaster Carr.
Gale Hawkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gale Hawkins Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2018 at 12:07am
Dorman 550-032 Concave Expansion Plug is a source I found on Amazon and some parts stores for our Model B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gale Hawkins Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 1:08am
They came yesterday in only two days.
We pulled out ours because they were 70 years old and it let us get into the block to clean out the gelled mess from running a mixture of coolant and oil plus stop leak. The coolant leak was from failed sleeve O-rings.
What a mess but today I finished the heavy cleaning of the inside of the block as well as the old pistons and sleeves so after a finish wash we will start putting the cylinder sleeves and cam bearings/shaft while we wait on the crankshaft.
Look like the B drank out of the pond with the other horse stock.
