forgot how sweet the 185 |
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3481 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Feb 2016 at 5:27pm |
last series run with bosch injectors. Cranks at 30 degrees with no assist. Amazing, the difference ; we only sold 2 or 3 of the last production run, crank driven oil pump.. Traded for one that had 38" rubber, quite an increase in speed as well. ... Wheeeeeeeee.....
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10695 |
I love the sound of that engine. Pretty nice to listen to all day. Sweet tractors.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8605 |
Post a picture for us to see
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8255 |
Dam luv those 301,s for sure , the 28,s kinda limited the horsepower to the ground effect, but wow you turn that 301 pump and 18.4- 34,s or _38,s , she,ll walk the dog!
Edited by DougG - 18 Feb 2016 at 7:04pm |
d17series4 ![]() Silver Level ![]() Joined: 21 Aug 2013 Location: Huntley MN Points: 444 |
I have a 2ft oversized straight pipe on my 185. Last spring my brother was pulling seed wagon up a hill at night and you see a little purplish orange flame coming out of the pipe. It was pretty tough looking
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
Don't want to hijack this thread, but I thought I would just post again these videos that I have posted before. This is my father's 185 that was purchased new in 1981. It is serial number 185 15616 and has a model 649 engine.Also a scan of a picture of me sitting on it in 1982.
[TUBE]http://youtu.be/o_qAlBJ_f8g[/TUBE] [TUBE]http://youtu.be/xQqC_Vcmx9c[/TUBE] ![]() |
bgequip.net then iron search then 185 - cant get link to work.
see if that will not work - on iron search http://www.ironsearch.com/TextSearch/IS-Top.aspx?x=185 http://www.bgequip.net/equipment-sales/ Edited by tbran - 19 Feb 2016 at 8:36am |
BenGiBoy ![]() Orange Level ![]() ![]() Joined: 11 Nov 2015 Location: Ashville, NY Points: 696 |
for tbran:
Those links should work. |
'39 Model B
Tractors are cheaper than girls, remember that! |
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3835 |
DanD I have been admiring that 185 for many years and didn't realize until now that it is one of the last ones made.
As for starting, mine is a pretty early version and had always started hard. I recently installed new heavy gauge cables and two group 31 top post batteries. Now it whips over briskly and will start down to about 32 degrees with no glow plugs, prior to that it needed glow plugs at 60 degrees. |
bauerd44 ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
Butch, what size cables did you put on your 185? Dale
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
WD45 ![]() Orange Level ![]() ![]() Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 954 |
Tim our 185 is equipped with a straight pipe and turbo. Everyone at the farm wants to drive it . It is one sweet tractor. We use gauge one cables when we replace battery cables on our tractors. Also have electric fuel pump on the 185.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
BigBadAllis ![]() Silver Level ![]() Joined: 18 Sep 2009 Location: Michigan Points: 90 |
I really love the 180 and 185 diesels. One of the best haying tractors. They will run forever on a tank of fuel. Also easy starters in the winter.
Jason |
The cables are 2/0 with ends soldered on. The 31 batteries are bolt type posts so we had to change the cable ends anyway so we upgraded everything from the ground to the starter and the difference it makes is huge. |
