Font Wheels for Model C Adjustable Axle.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: Font Wheels for Model C Adjustable Axle.
    Posted: 27 Sep 2011 at 1:21am
Wheels for Model C adjustable front axle.
The front axle tube is adjustable for width.
Are the original front wheels designed to be  mounted
either dished in or dished out to add even more
adjustment to the front track?
If yes, are there 5 or 10 holes? Consider the wheel
lug bolts use a tapered seating, and wouldn't reversible
wheels need proper matching tapered holes. And
wouldn't that require a second set of 5 holes?
Thanks,
Brian
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 6:26am
The parts book calls out the same wheel for the adj. C as other B's and C's except for in steel wheels.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 7:01am
I have not seen any reversable front wheels for any Cs, Bs or CAs. They all seem to be the same 5 hole for all the small units
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 4:32pm
Dad always turned the front wheels around when they were picking corn on his narrow front C.  Back in the 50's it always seemed to be muddy when we were picking corn. Turnning the wheels around kept them from packing with mud between them.  My grand father did the same with his Farmal H.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 4:37pm
your going so slow that it does not make much difference if the holes are countersunk or not. The factory wheels only have 5 holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2011 at 9:54pm
Ok, 5 hole wheels only. I thank all for their help. It's great we have
such a vast knowledge base here.
