Followed Me Home |
Author | ||||
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1066 |
![]() ![]() ![]() ![]() ![]() Posted: 04 May 2025 at 9:30pm |
I have long coveted an Allis Model CA, this one sorta fell into my lap for cheap. Loader, aftermarket 3-Point. ![]() The engine was lightly stuck but my 14 year old Grandson had it freed up the next day. The carburetor needs cleaned, etc. before trying to start. ![]() It has some issues with the steering box. ![]() |
Sponsored Links | ||||
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 85746 |
CA steering box arm normally points UP... Yours points DOWN like a model B.... maybe to get it away from the loader frame ?
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5139 |
Never seen a loader on a CA, neat find. Good luck with it and hope you get it going. The extra length arm is for extra leverage steering I’m assuming due to the extra weight of the loader?
ekjdm14 ![]() Orange Level Access ![]() Joined: 20 Aug 2024 Location: Manchester UK Points: 767 |
Not sure on that, extra length on the drop arm would surely = less leverage?
What's the score with the negative camber on the front end too, is that normally how the adjustable WFE would sit & the one on my B is just wore slap out? Looks like you've got wider automotive tires like I do but mine just rub at the top of the knee, basically straight up/down with no camber at all. Love the loader set up, that & the 3 point would come in super useful about now! (and bits of your carb haha!) Good luck getting her going, looking forward to seeing another small one live again
Stuck Farmer
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4939 |
A loader on a CA: That's surely asking for steering gear issues. Whoever added that extra length has thing basswckwards. That lever needs to be shorter for extra leverage. If you plan on keeping the loaded on it, it looks to be a good place for a FarmerFix of a replacement power steering box from a car or light pickup.
I suppose that the original front axle gave up from the abuse the loader added, since it was replace with a D12 axle, needing the arm to point down.
If it was here that 3pt would be on the scrap heap, the only thing they are good for are pinched fingers and a bad back. Snap coupler is the best hitch ever produced |
Not sure what this steering box came from but it has massive amounts of slop. I like the idea of finding a power steering box to scab in there.
Thanks for pointing that out, I did not realize it was not a Model C axle; I have never so much as seen or touched a D12 so wouldn't have recognized it as such.
Trouble is, I own a half dozen 3pt implements and exactly one snap coupler two-bottom plow. Snap coupler tools are scarce as hen's teeth around these parts
Yup. Less leverage
PaulB pointed out that this is a D12 axle so I guess that's just how they were made? ![]()
We hope to get some use out of it around the homestead for sure ![]()
We got it turning over freely with the starter now and found some sparks so now just need to get the carburetor to carbureting.
Great stuff, didn't realise the WFE wasn't correct either. perhaps as Pauls says accounts for the drop arm & camber angle.
Lovely simple carbs to go through though, especially when the 200lb gorilla on the other end of the tools doesn't twist bits of them right in half lol Power steering would be great if you can make it work, after all the hydraulic pump is already there so should be easy.
Edited by ekjdm14 - 23 hours 44 minutes ago at 9:15am |
Stuck Farmer
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8433 |
Les,
Welcome to the CA club! You have several mods that will be interesting. What are your plans for the tractor? Sounds like you have a good helper to get it going! Regards, Chris and Cheryl
that 3 point will be VERY HANDY around a small homestead / farm.. I have a "home made" one on a B and keep a blade on it.... 2-3-4 the tractors have sickle / belly mower / drag disc..
and the loader will come in hand.. Use ocasionally as a fork truck or to move small loads.. Not a FULL TIME LOADER... but VERY HANDY for light use on SMALL farm. Worn out gear boxes are normall for the B- C tractors.. Not hard to disassemble and repair..... i assume Paul means you have a D12 gear box in addition to the axle.. Bigger than a B, but probably easy to disassemble.. parts may be a problem.
Edited by steve(ill) - 20 hours 3 minutes ago at 12:56pm |
No. That is a CA box farmerized to work with the D12 axle. The CA box is a little bit better than what B&C boxes are as the CA box has 2 pins to the B or C single pin, however not up to loader service by any means. The D10/12 box is only slightly better than a CA one and parts are next to impossible to find.
Plan is to just get it running and then evaluate what it can and cannot do. This is mostly a project for the Grandson to advance his skills. So far I am into it $200 and a tank of gas for my Son-in-law to haul it home.
you got that much value in the HITCH or Rear Tires !!
Yup ![]() He also sent along all of the original snap coupler hitch parts. The battery was toast though ![]() It is still 6 Volt Positive ground, the generator appears to have a regulator rather than just a cutout switch. The ammeter shows discharge when the ignition is turned on as well as the headlights, so at least some of the wiring is functional. The starter spins the engine briskly with all of the spark plugs out. The carburetor throttle shaft and choke shaft are stuck, we boiled the carburetor today and it is now soaking in ATF/Acetone mixture. The engine oil looks good enough to run. Probably will change it first though.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3017 |
At any rate a pretty interesting tractor
Bargain at twice the price Les, highly envious. Glad your battery was dead though, that might have sent me over the edge!
![]() Joking aside that's a roaring deal, would definitely recommend changing oil before you run as a lot of the crap can settle out when they sit & make used up old oil look brand new. Might be the new oil blacks up pretty quick too once she stirs up the pan but cheaper to do a couple of changes than a rebuild.
Stuck Farmer
