Flywheel bolts- Torque setting?
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Flywheel bolts- Torque setting?
    Posted: 01 Oct 2011 at 1:27pm
I am going to be putting the new clutch on my WD45 .  Is there any torque settings for the flywheel bolts?  The shop manual doesn't list anything.
Help is much appreciated!
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 1:37pm
For the diesel they say 95 to 105
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 1:40pm
Mine is gas.  Sorry I didn't clarify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 2:32pm
I figured that.
I would think the diesel specs would be pretty close to the gas if not the same.
I can't count the number of engines I built by just getting them good and tight without knowing what torque they were at.
After you get them evenly snug go around again with a small 1/2 breaker bar.
You should be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 5:46pm
The gas is lower, it's either 65 or 85 can't remember for sure, and my book is out in the shop.
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 6:20pm
My service manual for WD45 gas flywheel says,
lockwashers and capscrews, tighten to 50 ft. lbs.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
This page was generated in 0.227 seconds.
